Question about RCA P61310 TV
It keeps turning on and off by itself!!!!!!!!
Is it my fuses or can i buy these fuses and put them in myself.
2001 suzuki vs800 new battery still no power.
Check the MAIN FUSE located near the battery. This fuse looks like it is just a strip of metal but it protects the entire motorcycle. The wire from the battery leads directly to it.
Good Luck
May 14, 2014 | 2001 Suzuki VS 800 Intruder
My phone keeps turning itself on and off, can I fix this myself?
Yes, just keep the battery out for 5mins and then put it in and restart your phone. If that doesn't work then take everything out of your phone like
SD Card, Battery.etc Then leave it for a while. Then restart it and see if it works fine AND if it doesn't theeen I'm sorry but I don't know.
Feb 26, 2013 | Nokia lumia 610 NFC unlocked gsm phone
My 2005 Toyota Tacoma keeps blowing the turn signal fuse. Any ideas on what may be the problem?
bad bulb will cause it i had one that all the lamps lit ended up being a shorted bulb buy a two back of bulbs i think they are 1557 try changing both fronts first if it still blows put originals back in and try the new ones in the back or isolate it to one side which ever side blows it also could be a short in the switch itself
Jan 20, 2013 | 1995 Toyota 4Runner
I keep getting an echo of myself when speaking on the phone
Try turning off the phone, removing the battery, leave it out for 30 seconds and put it back in. Turn it back on and place a test call. You may also want to try calling from a different physical location, maybe many miles away, to see if it is just that particular cellular coverage area. If the problem persists then it sounds like the phone itself has an issue and should be replaced.
Sep 09, 2010 | Samsung Cell Phones
A hager b6 fuse has blown - normally the switch flips off and you push the switch back to on and power is restored - here the switch is limp and wont stay in the on position - i cannot see how you remove...
I have just done this myself and without blowing myself up.
1. Tools needed will be a torch and a philips screwdriver
2. Switch off your mains.
3. Check your mains are off
4. On the fuse itself they are two screws. One above the hager sign and one below. Unscrew these. The top screw keeps the wire in from the mains and bottom screw is to keep fuse screwed to the actual fuse box
5. You should be able to remove your fuse now
6. On your new fuse there will be a white piece at the back. Pull that down
7. When the fuse is removed you will see the wire which is now free and on the bottom a plug which is where your new fuse slots in.
8. Slot your new fuse on the plug and tighten the bottom screw.
9. Put your wire in place on the top of the fuse and tighten the top screw.
10. Switch your new fuse on the "on" position.
11. Put back your cover on your fuse box
12. Switch your mains back on.
WHO NEEDS A MAN! PS ONLY ATTEMPT IF COMPETENT OR GET A QUALIFIED ELECTRICIAN!
Sep 12, 2009 | Electrical Supplies
SD533HD5 Blowing Fuses
No lo creo ,ya que el problema puede ser el circuito horizontal checalo o manda la tv a un taller.
Mar 17, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
RCA P61310 TV Logo
35 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
