Question about Miele W404 Washer
Miele w404 dead not lighting - Miele W404 Washer
  • 177 Answers
Firstly check the power. secondly check the door is closed properly and push hard on it as the door lock needs to be engaged for the light circuit to then light up. it could be a faulty door lock
Posted on Aug 18, 2010
No power to Miele W404 Plus washing machine.
hi
it could be faulty flex cable from the washer to wall socket or where the flex cable is screwed into the terminal block inside the machine come out or broken
Dec 21, 2017 | Miele Washing Machines
Why is my washing machine Miele w404 making thudding noises on spin Plse?
Unbalance load???
When in spinning cycle, does your drum start shaking violently and hitting the washer outer walls. Out of balance load.....
Is your machine on level floor. Does it have a play on legs while sitting doing nothing???
Happens for every load, then may be your washer shocks and/or top coil springs have come out or broken..
Or machine drum counter weights broken and drum going out of balance.
Apr 25, 2015 | Miele Washing Machines
Miele W404 not heating
sounds like you need to replace the heating element. Not too difficult as in most washers it is basically a huge version of a kettle heating element. Look up on line how to replace this for your model of washer.
Feb 24, 2013 | Dishwashers
My Mom has miele 404 and when at the end of washing cycle, it has some strange noise. anyone may know what that could be?
there is something hitting the propeller on the pump most likely loose change or bobby pin or whatever forgets to come out of pockets check filter first & try to clear it out from there.
Jan 19, 2011 | Miele W404 Washer
Dosent spin at end of programe has to be done manual
Hello,If you are having a problem with your top load washer then check out this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
Thanks
May 28, 2010 | Miele W404 Washer
Leaking door seal on a W404 Plus
Make sure the door is closing properly,and check the door is not loose, and that there is no build up of lime scale on the door glas.
If all o/k, then only solution is to replace the door seal.
Jan 18, 2010 | Miele Washing Machines
Can you replace the door seal on the miele w404 washer as it is mouldy and we have been unable to clean it?
YES IT IS EASY TO REPLACE:
YOU HAVE 2 RING OF TIGHT:
1-BETWEEN THE OUTER CASE AND the door seal
2- BETWEEN THE SUD CONTAINER
AND the door seal
USING SMALL PLAYER AND SUITABLE WRENSH ,SCREWDRIVER
THANKS
Jul 28, 2009 | Miele W404 Washer
Miele W404 Washer Logo
379 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
