I have a 21 inch crt Monitor. It works fine in all other rooms except mine. In my room the display rolls upwards from the instant it is switched on. Please guide me as to what is causing this vertical rolling/flickering.
  • 4,737 Answers
This is usually caused by electrostatic affect from the environment. Make sure there's no other objects like Speaker (woofer) beside the monitor, below or above, behind or front. Try by turning it to different direction. I hope this will solve your problem. Good luck..
Posted on May 16, 2010
Black color rigth side and black color lower crt tv 21 inches
onida black 21 inch displaying enter password please help me
Apr 19, 2014 | Sanyo DS31520 31" TV
I have a 21 inch CRT Monitor. It works fine in all other rooms except mine. In my room, the display rolls upwards from the instant it is switched on. Please guide me as to what is causing this vertical...
its the Hz it is set on the "refresh rate" it is likely you have in all other rooms except yours teh same kind of lighting and in this one room it likely has the same Hz lighting as your crt monitor set it above 60hz and you should be fine.
Mar 25, 2010 | Computers & Internet
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
CRT works but LCD doesnt
You may need a driver for your PC as lcd differs from crt. They have a different signal input so update the video card drivers and you should be good to go.
Jun 30, 2009 | Computers & Internet
ViewSonic VA912 half screen dead after 30 minutes
first i confirmed that the problem was in lcd.then i predicted that some display chip on the motherboard are getting heat.due to which the display was performing irregular then i switch on A/C of my room.and the temperature was cool. and the monitor was working fine.
Apr 29, 2009 | IBM E54 (Pearl, White) 15 in.CRT...
CRT monitor's background colour is changed to dull yellow colour
hello,
i think this problem accure due to chage of CRT CATHODE. if you are not a hardware engineer then check it from hardware engineer. any crt monotor have 3 RGB Cathode to release electron on screen. the electron comes shodow mask and create a pixel on the screen the pixel make a picture. The RGB color make the perfect picture. if your picture is dull then i think that happen due to less negative chage of Cathode or any Crt base Bios ic is failior. so you have to checked it from hardware engineer.
ok
bye
Oct 22, 2008 | Samsung 21" FLAT CRT COLOR MONITOR
CRT monitor too bright
I have/had same problem. I have ATI Radeon display adapter and in driver settings there was adjustment for brightness. I adjusted that to minimum and now the brightness is pretty good (still little bit too bright, monitor setting 0%). Other succestions welcome...
Sep 28, 2006 | Keytec Sony Multiscan E500 21 in. CRT...
Computers & Internet Logo
David Payne
David Payne
