Question about Brookstone Pure-Ion UV Air Purifier
Cleaned the filters and is mking a noise!!!
Cleaned the filter and its making a noise
  • Anonymous May 15, 2008
    how to remove the filter from the purifier
  • 981 Answers
Get someone with some mechanical sense to get it out; watch what they do. You could have checked the manual or the maker's website, could you not?
Posted on Jun 23, 2008
Resetting Filter status after cleaning filter
MAKE SURE THAT THE LID OF THE FILTER IS PROPERLY CONNECTED SOMETIMES THESE DEVICES ARE
BUILT WITH SWITCH FILTER
Jan 13, 2014 | Honeywell Air Purifiers
How do I fix the noise?
let it dry completely, disassemble as you would for cleaning, and remove filter unit. Inspect to make sure no paper or other debris like a seal has been dislodged. If you can see fan blade, see if it will turn with filter removed. If it moves easily, reassemble carefully and make sure the contacts are oriented correctly and any charcoal filter is on place as well. Try unit.
If noise persists, the unit has to be opened up to inspect bearings of fan/motor and to locate and remove any debris. At that time a drop of light sewing machine oil or pellet gun oil to lubricate the bearings is a good idea.
Jan 23, 2012 | Air Purifiers
Has not made the zapping noise in a long time...I know my house is dusty :)...used to make the noise before...is the cell worn out or broken
The air intake filter probably needs cleaning or replacing. If it needs replacing, you will have to buy that from your local Oreck dealer.
Mar 20, 2011 | Oreck XL Professional Air Purifier
CLEANED FILTER. PUT THE FILTER BACK IN AND NOW IT IS MAKING A CLICKING NOISE. TOOK THE VACUM TO THE FILTER AND IT IS STILL MAKING THE NOISE
The clicking noise is the sound of the high ionizing voltage 'shorting' due to dirt or humidity or both which provides the pathway for discharge. Cleaning and completely drying the filter(s) does not always help, in this case switching the unit to a lower operational speed can mitigate this problem. New filter(s) may be needed to resolve the clicking.
Sep 13, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Honeywell Furnace Air Filter clicking noise after cleaning it
I also have this problem as soon as I pt a new filter in - does anyone have a clue what this problem is?
Apr 09, 2010 | Honeywell (F50F1032) Air Purifier
Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
Aug 13, 2009 | Sharper Image Ionic Breeze 3.0 Air...
My pureion makes a crackling/ticking sound when running;
Its just a wear in the ozone plastic its normal after continued use
Mar 22, 2009 | Brookstone Pure-Ion UV Air Purifier
Unit 8 mos. old and now makes loud, awful noise
you have had the thing for 8 mos try cleaning the hepa filter with a vacuum use the brush type attchment or u might have defective filters go to kaz.com or contact honeywell
Jun 24, 2008 | Honeywell HHT-081 Air Purifier
Annoying ticking
My air purifier was doing the same thing. The ticking noise you are hearing is caused by dust build up on the ionizer pins. When the ionizer pins collect too much dust, they tend to start making the clicking/ticking sound caused by static electricity. The solution is simple. Take the filter out and clean it real good (follow directions on filter on how to clean). Now, with the filter out, if you look down inside the vent where the filter was, you'll see a white piece of plastic with nine holes in it that are about the size of a silver dollar. Directly in the center of each hole there will be something that looks like a needle, those are the ionizer pins and they will probably have dust built up on them. Next, with the filter out, blow out the air purifier with compressed air to clean all the dust off the ionizer pins. This should take care of the problem, it worked on mine.
Dec 02, 2007 | Kaz Honeywell QuietClean HFD-135 Air...
Brookstone Pure-Ion UV Air Purifier Logo
138 people viewed this question
Top Brookstone Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
