Whirlpool Duet Sport ht front loader is stopping before cycle is over...clothes are soaking wet and it takes a couple of trys before I can get the drain and spin cycle to work.
First check your washer plug to see if the connections are tightly
screwed. Next check your filter if you haven't for long.
Remove
the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. If not solved, something
shd be blocking your pump, check this out
How abt a nice rating
for the free help? Thnks
My whirlpool duet washer isn't going through all the cycles
