Question about Dell Inkjet 720 Printer
Won't print magenta
I put a new colour cartridge in and it is not printing magenta. the black, yellow, and blue work fine. any suggestions?
  • macman21 Mar 31, 2008
    yes the protection paper is off, i have cleaned the cartridge, and done an aligment. the yellow and blue ink come outs perfectly but the magenta does not. defective ink cartridge you think?
    Scholar:
  • 141 Answers
Did you peeled off all the protetion paper ??? Make sure your contact in the carriage are clean, maybe just make a calibration off color or an aligment
Posted on Mar 31, 2008
  • Patrick St-Jean
    Patrick St-Jean Apr 01, 2008
    Maybe, but before you change your cartridge try this, Put warm water on a soft tissue and gently press your cartridge on it. You will suppose to see ink on your tissue. If it doesn'T work try a new one....
Brother hl-3045 jam inside
Had the same problem, called help center and fixed it!!!
Problem occurred when i tried to print colour labels from Word.
Black cartridge printing worked fine.
When using manual feed (pull down black panel in front which says 'brother'- you'll get the message for this if printing labels
you must open the back door of the printer.
got 'paper jam inside' error message.
Here's what I did and somewhere along the way, something worked.
Turn and unplug machine
take out all drum cartridges (all 4)
Take out the black belt (everything you can remove has a green arrow or tab- easy)
check to see if there's any paper in there- there was no paper in my case.
separate the drum from the cartridge for each colour and check the colour roller and the fuser film roller- don't touch them- no paper stuck that i could see
put them back together carefully.
Put the belt in and then the 4 cartridges
do a test run- mine still showed error message- paper jam inside
switch black with each cartridge and do a test run for each. When i switched with yellow - didn't work, magenta- didn't work- cyan- WORKED!!!- the colours were messed up on the document but it went through and printed without the error message.
Here's the sequence of what colour cartridge went in which spot.
Yellow in black slot
magenta in yellow slot
cyan in magenta slot
black in cyan slot.
then i switched them back to the way they are supposed to be and tried to print again and it worked!
the colour is amazing on this printer- i had the trouble right from the beginning after installation.
hope this helps.
Nov 21, 2012 | Brother HL-3045CN Laser Printer
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
My printer is hp laserjet cp 1515n. After printing some documents it writes "printing cool down mode" and begins working very slowly. Please help me
1515n - I have the Magenta colour 'shadowing' the blue test. A mirror image of the blue text. [slightly staggered] Black is fine. Applies to all Word docs when printing in blue - can you help please?
I only use genuine cartridges.
Thanks
Jules Radstock
Jul 23, 2010 | HP LaserJet CP1518 Printer
Too much red
I'm assuming that the colour cartridge is a three in one. Blue, Yellow and Magenta.
When printing a colour document, the printer automatically balances colour mixtures from the three primary colours listed above. Should a print out be too red, its probably because its run out of yellow and/blue.
The best way to check is to print out a test page, you should get a block for each of the colours and black. If one's missing, there's your answer.
Apr 29, 2010 | Dell 922 All-In-One InkJet Printer
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
My printer will only print in blues pinks and purple and black and white
ur printer prints in blues pinks n purple: its very simple :there r three prime colours in ur colour cartridge that forms all the other colour variation they are cyan, magenta n yellow. ur yellow colour in ur cartridge is either dried or empty thats the reason its not printing the colour variations which requires yellow. the solution is to either get ur colour cartridge refilled or replace ur colour cartridge. rate this solution as fixya n encourage us to help u solve ur problems in future too.thanks 4 using fixya.
Jun 12, 2008 | Office Equipment & Supplies
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
57 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
