Question about HP Pavilion a620n (PC028A) PC Desktop
I press the power button at the front of the tower and it doesn't activate the pc power.
  • joecoolvette
    joecoolvette May 17, 2010
    I believe it's time to see whether the problem is simply the Power on switch, (Located inside the plastic Power On button), or if the problem is the Power Supply. Do you know how to bypass the Power On switch? (Example of a Power On switch replacement, that may fit in your Gateway's plastic Power On button,http://www.directron.com/atxswitch.html ) Please post in a Comment.
Probably electricity supply problem
Posted on Jul 27, 2010
How do i remove the front cover of my dell computer tower 8250
Not sure if you can pull the front cover off this particular model, but to open the PC:
  1. Make sure the PC is powered off and disconnected from the AC outlet.
  2. If facing the front of the PC, lay it on its right-hand side, so it lies flat.
  3. At the back of the PC at the top left, there is a release button. There should also be a release button on the bottom of the PC near the rear (slightly indented into the bottom). While pressing both of the release buttons, pull the cover upwards and the case will open like a clam.
Jul 18, 2014 | Dell Optiplex GX150 Tower Computer - 1GHz...
FIXYA The power supply output of my Dell Dimension 8200 desktop pc is delayed for minutes after i press the ON button in the tower front. The momentary button switch is OK. The delay is 15 minutes if
It's not about the switch, a problem may be caused by bad power management control driven by XP. Ask on DELL's forum about any patches about this. Finally, check-up your power management scheme.
PC Servis Kompjutera Kod FONTANE Popravka Odrzavanje Laptop Racunara
Mar 06, 2014 | Dell Computers & Internet
No instructions on how to open and shut down my asus tower of my compyter.
Press the power button, usually on the front of the tower to switch it on and use the power button, lower left of desktop, to switch it off.
Dec 05, 2013 | ASUS Eee 4G Notebook
On off button not working
We need to follow some Troubleshooting steps
power off the tower
disconnect the power cable
1.open the side panal of the tower
2.then open the front panal of the tower
3.the please toggle the power button from inside the tower
4.then put back the front and the side panal
connect back the power cable
restart the pc using the power button
it will start working
Jan 13, 2011 | HP Compaq Presario SR1830NX PC Desktop
No power to tower. Pressing power on button on front of tower fails. Is there some kind of reset or fuse to look for?
There is no easy fuse. Did the computer get turned off at the back? Some power supplies have a switch on the top of the tower. Did the power strip get turned off? Have you verified that the outlet has power?
If this is not the problem, it sounds like a blown power supply. Do you have any lights on the system? If not, take the tower to a local computer shop and they can very quickly diagnose a failed power supply.
Sep 07, 2010 | Dell Dimension 4550 PC Desktop
There is a green blinking LED on my motherboard, and my computer is not turning on. What is wrong? Someone told me to ... Hi, i have a dell Optiplex 780 running windows xp, the computer button is just...
If you are referring to the green light on the system tower and is blinking the problem could be the system is in stand by mode.
Turn off the computer by pressing on the power button on the system tower for 10 seconds.
Disconnect the black power cord at the back of the system tower and then again press the power button on the tower for 10 seconds. There would be no activity on the tower when you do this.
Reconnect the power cord and then power on the computer to see if the issue is resolved.
Thanks for using Fixya
Proton
Aug 30, 2010 | Dell XPS 200 PC Desktop
MY DELL IS OPTIPLEX 760SFF, IT NOT BOOTING, SHOWING AMBER LIGHT ON THE POWER BUTTON WHEN PLUG TO POWER.
If this the light is solid amber in the front of the computer.Try doing the following steps
1. Disconnect the power cable from the back of the system tower. Press the power button on the tower 30 seconds.
2. Reconnect the power cable to the back of the system tower and power it back on.
If the amber light is on the monitor power button and the tower power button is off or blinking amber it could mean that it is a bad power supply.
Thnaks for using fixya
Proton
Aug 10, 2010 | Computers & Internet
When pressing the ON button it will not respond that fast it wont power up in short ... but waiting for a very long moment press it once again and it will be powered up .. what do you think was my pc...
Could be a static build up on the motherboard. Disconnect the power cord from the abck of the system tower and press the power button in the front for 20 seconds.
reconnect the power cable to the tower and now power on system.
Thanks for using fixya
proton
Jun 09, 2010 | HP Pavilion A6010N (882780985575) PC...
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
HP Pavilion a620n (PC028A) PC Desktop Logo
78 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
