I have a used computer and the person before a wireless connection and I have a cable connection and it not recognize my ethen cord. I disconnect the wireless service but it still not recognize.
  • 4 Answers
It seems that your LAN Card or Network Interface Card is disabled , go into the device manager ( Start ->Run->cmd->devmgmt.msc ) Now in device manager you will see Network Adapter expand it and then you will see one Wireless Ethernet Adapter and another Ethernet Adapter ( this is you LAN adapter to which the cable will connect to ) Right click and Enable this.
Let me know if this helps
Posted on May 17, 2010
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Pc does not recognize external drive
External hard drives are plug-and-play devices used to store music, video and data files.
Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Jan 07, 2013 | SmartDisk Verbatim 96867 2 TB External...
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
How to connect our printer to our computer
disconnect printer from computer -- prepare two cables and drivers -
(USB cable and power cord, along with CD software drivers )
install s/w (software) by inserting CD in drive bay -- allow for auto run to occur
install drivers , follow instructions.
when prompted connect power cord to printer and to Ac wall outlet, then connect USB cable to computer
continue following onscreen instructions. printer will be installed automatically and will be recognized by computer
send me 4 thumbs up please.
Jan 11, 2011 | Epson Office Equipment & Supplies
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
Wireless is working but computer won't connect to the internet
Remove the power cord from the router. Wait 30 seconds. Reconnect the cord. Like rebooting a balky computer.
You may also have other routers nearby on the same broadcast channel.
Occasionally cordless 2.4ghz phones may jam the wireless channels.
Chose another channel from the router setup.
Aug 06, 2009 | Belkin (F5D8231-4) Wireless Router...
Computer does not recognize it
assuming your using a windows xp or 2000 os, try another cable if you have one..turn the gps off, plug in the usb cord and restart the gps. if that fails, if the cable is connected to a port on the front of the computer,move the usb cable to a rear port on the computer and try the previous way i just explained.
if those fail, disconnect all usb devises connected to the pc and restart the computer and try again. (always use a rear port on the pc if you can)
good luck
Aug 03, 2009 | Magellan Maestro 4040 GPS Receiver
What does the wireless botten look like? i just got wireless today and i just kant find it i dont alwayz wana use the cord to get on the interent
You will need a network cable to attach the wireless router to your computer to set it up. You want to enable security to block others from using your connection (read your manual). Once that is set up, you can disconnect the cable from the router and computer.
In the system tray, lower right of screen, look for an icon of a monitor with or without a red "X". Right click on it and select "View available wireless connections. Choose yours and connect. Type in your security KEY and you will be connected wirelessly to the router.
Jun 23, 2009 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Open Questions:
USA:AOL@ 1~866:201:6261 password reset CONTACT AOL Tec*h SuPp0Rt 24/7geniusmad*! Here USA AOL MAIL Tech support phone number help provide by AOL MAIL technical regarding your Issues call I~866~201 6261.AOL MAIL customer service phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL SUPPORT phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL tech support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Technical support phone number I~866~201 6261USA\CANADA AOL MAIL customer support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Tech support phone number I~866~201 6261USA\CANADA AOL MAIL Support phone number I~866~201 6261USA\CANADA AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number .AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical phone number. AOL MAIL Customer support phone number. AOL MAIL Support phone number I~866~201 6261Helpline care .AOL MAIL Tech support phone number. AOL MAIL Technical support phone number. AOL MAIL Customer support phone number
Jan 20, 2018 | AOL Computers & Internet
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
