Monitor keeps turning itself off after a very
Monitor keeps turning itsel*** after a very short time.green power light stays on
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 16, 2010
Montitor display turns off. Not power, green light stays on.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Similar board: http://www.lcdrepair.us/SE178WFPcinverter-power.html
May 14, 2010 | Dell SE198WFP LCD Monitor
Monitor keeps turning itself off after a very short time.green power light stays on
if your have spare monitor try to replace if it function normally the problem may be in vga cable connector of in monitor ckt itself, if same problem that monitor not pickup signal trace first if cpu still in on function, if so try to add video card and observe.
Mar 25, 2010 | Computers & Internet
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
AS501 Monitor Problem
Your monitor have a bad condensatorin the PSU.
The only thing to do is to replace the Power Supply Unit (very expensive) or if you have electronic tools, found and replace that condensator.(cheaper way...)
Best Regards!
Jun 24, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Computer monitor flashes on then turns off
Try the monitor with another computer. If it works, the video circuitry (whether it is on-board or a separate adapter) in the Gateway is the problem and needs to be replaced. Otherwise, the problem is with the monitor itself. From your description it is probably the Gateway's video that is the problem since the power light on the monitor remains green indicating that it is seeng a signal, but not something it can properly interpret, i.e., one or more of the control signals are shot.
Mar 21, 2009 | Computers & Internet
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Flatron LG monitor safe mode
Your monitor goes to Power Saving Mode when the signal it is receiving is not correct. In all probability this is not a problem of the monitor itself, rather you should check the connections and the computer the monitor it's connected to. For example you could try a different RGB cable and try it in a different computer.
Apr 13, 2007 | LG Flatron L1951S 19" LCD Flat Panel...
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Open Questions:
Cervical Cushion- Pillows for Neck Pain Are you a very sedentary person? Do you have a classic office job and are 8 hours or more sitting in front of a computer? Then you most likely suffer from cervical pain. Cervical pain means having severe pain in the neck area because of an incorrect position of our cervix for quite some time. The cervical block or its numbness is due to the unnatural compression of the vertebrae. In this guide you will find all information about cervical pain, how to prevent them and how to cure them, but above all you will learn how to choose your cervical cushion that will help you lessen the pain or make it disappear completely. In the following table you will find some models of cervical pillows that can be found on the market, along with some of the major features that distinguish them. How to Choose a Cervical Cushion Since on the market you can find a great multitude of cervical pillow models, choose the most suitable one and certainly not a small business. First of all, choosing the most appropriate one is to understand what pathology you are suffering from. Although we often call it neck pain, cervical is not always the same in all cases. In this regard, it is understood that not everyone can use the same cushion. There are cases where the patient needs a more flexible pillow, others where there is a need for stiffer material, so before buying your new cervical cushion it would be interesting to consult your trusted physician, who can visit you and decide for you what is best suited to your pathology. Another factor could concern the price, but being in the medical field I recommend closing an eye on this item, ten euros more or less are nothing when it comes to health. Moreover, the price is directly proportional to the quality of the material used and of course there are materials that cost more than others. So as you see there are several factors to consider. Take care of all the advice you'll find on these pages and you too will be able to make the right choice. What is cervical pain and remedies? The area of ??the cervical vertebrae is that portion of our body that accuses so-called cervical pain when our neck or our head is in an incorrect position for several hours. This area is very important for our health and our well-being. In practice it connects our body and especially the spine to the head, with all the nerve endings that pass right in this particular area and very sensitive. When this area is subjected to a continuous stress, we do not only pain neck pain, but we also compromise the proper functioning of the head movement. Very often the pain becomes so strong that besides affecting the neck, it moves to the upper shoulders and joints, causing the famous head turns and also nausea. In the most severe cases a capatina is recommended by your doctor. Among the various factors that can trigger these severe pains are incorrect posture or an improper pillow. At the origin of this evil, however, there are also muscle contractions, trauma and stress. For this reason, the cervical pillow was born, which relieves the pain and allows the neck to be in the correct position. Structure, shape and material are designed to fit perfectly to the shape of the neck, sustaining it and giving it relief.
Oct 23, 2017 | Major Computers & Internet
Computers & Internet Logo
230 people viewed this question
David Payne
David Payne
