Question about Galileo New Age 800x80 Telescope
I dont have a clue which end is suppose to be facing upward.
I tried looking both ways and I cant seem to see out of the scope at all.
  • 3,186 Answers
Put the eyepiece with the largest number written on it into the telescope. Go outside during the daytime and practice focusing on a distant object.
Read this and look at the pictures:
http://www.texasastro.org/telescope.php
Posted on Jun 01, 2010
I have a 13hp motor and with sparkplug removed and belts removed, when I turn flywheel by hand motor seems to have tightt Spot and noise like bearing or crank knocking??
do compression test if cant do one do to noise or limited turn over then yes possible blown engine --rod bearing failure only way to be certain is pull head and check the lower end or if have a scope drain oil look for filings and use scope to inspect
May 02, 2018 | Health & Beauty
How doo we find the clue in the mission NMPD
NMPD, I don't really remember, but I am pretty sure it is a Sniper Rifle hanging in a telephonewire or whatever.
Yeah, I am pretty sure now, you go to the round thingy, and then you look upwards and you will see a sniper rifle hanging. :)
Aug 13, 2012 | Microsoft Halo 3 for Xbox 360
A new telescope has a rubber piece on the end with screws cant see through is it supposed to be removed ?
That is the end with the MIRROR! Turn it around-- the focuser is on the UP end of the telescope and the PICTURE that Fixya uses (above) is ALSO mounted upside down! The scope above is pointed at the ground!
Many beginners mount the scope backwards.
Apr 10, 2011 | Tasco Luminova 40114675 (675 x 114mm)...
Hello there. just a question about my telescope. it looks like the baska . all it has is a model number 70060. view finder is upside down ( apparently that is normal). but when i look through the main...
You are using an erecting diagonal mirror between eyepiece and the scope. This flips the image (normally inverted as you realise) upright, but does not correct the reversal from side to side. These are often supplied with astronomical scopes more for ease of looking through the scope without craning one's neck upwards, rather than for the purpose of erecting the image.
There are other types of erectors that will fully erect the image if it bothers you, but astronomical telescopes normally are used without concern for such conventions, as the erecting lenses or prisms absorb light and introduce aberrations or reflections. If you wish to use the telescope for terrestrial work, you would probably be better off with a "spotting scope" which will be fully corrected for image orientation.
Jan 22, 2011 | Barska Optics Barska AE10094 - 70060, 525x...
I had a gunsmith install my Konus #7234 3x9x32 and the instructions were not forwarded. Q. As I look down the scope at the target, the adjustment labeled left (with arrow) is that oriented like my left...
yes it should be,,,to zero your scope clamp your rifle down so it wont move and fire into a target look at the hole the bullet made and if the cross is not on it move the cross till it is over the hole,,,dont move the gun till you have lined up the cross with the bullet strike,,,,,you should zero it in 3 shots this way?
Aug 28, 2010 | Konus hot Rifle Scope 7234 Matte 3-9x32
Whirlpool Thin Twin YLTE6234DQ2 washer is leaking water from the bottom. I need to remove the front panel to see what the problem is but can't seem to get it off. I have looked at suggestions to push in...
have you looked near the bottom of the front panel near the floor,there are 2 or 3 screws located at a 45 degree upward angle(to hide them from view) so they dont show,remove these and the front should hinge upward like an auto hood and the clips near the top should let go when its raised far enough upward
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
If you have a telescope with a MIRROR then the end with the focuser is pointed UP.
If you have a telescope with a lens in the front and and the focuser on the end, then the end with the lens is pointed up.
Read this and look at the pictures that show which end is UP:
Mar 25, 2010 | Galileo New Age 800x80 Telescope
Which way is it suppose to be put in it confusing me on my air filter on 92 roadmaster
hi, the rubber running around the edge needs to be facing upwards so that the fins on the filter are facing down, hope you under stand that.
The fins need to be down not up so facing upwards you should have a smooth surface.
Let me know if you have problems understanding what im telling you
Jan 15, 2010 | 1992 Buick Roadmaster
How do you load brads into the Arrow t50pbn staple gun?
Look at rear handle and push in tab then pull out load brads. Please Rate Thanks
Jan 08, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Galileo New Age 800x80 Telescope Logo
Top Galileo Optics Experts
NOEL
NOEL
Are you a Galileo Optic Expert? Answer questions, earn points and help others
