My akai mpk49 will not turn on from the usb or the power outlet i was woundering if their was a fuse inside i might need to replace?
I'm also having the exact same problem. I have taken it apart and tested a voltmmeter on the main PCB. Got a response from most of the connections except one. I'm afraid you and I are in the same boat, in need of a replacement or a new PCB. Problem there is Akai is not the best with customer service and a replacement can run $100 .
Posted on Jun 18, 2011
Some keys on mpk49 do not play unless hit hard
sounds like dust, if you know some one with an air compresser ask them to give it a blow through, if not then it is down to caned compressed air, if that is not enough, you need to open it, and clean the contacts (DVD cleaner is cheap and good)
Aug 29, 2014 | Akai Mpk49 Mpk 49 Midi USB Keyboard With...
How to fix usb port on keyboard controller
I am assuming that you broke the connector off the pcb board? you need a soldering iron about 30W and solder and flux, to remove and short circuit after you solder them back on, using a magnifying glass to make sure none of the 5 termnials are shorted
Our akai pdp6065ta 60" plasma hd tv will not turn
Try the power button on the tv. Your remote may have dead batteries. If no luck still, it sounds like your power supply unit has gone south. Check for warranty before attempting to repair.
Feb 18, 2011 | Akai PDP6065TA 60 in. Plasma TV
Tv will not come no timer lite blinks
Things You'll Need:
  • Electrical outlet
  • Fuses
  1. Check that the power cord is securely plugged into the power outlet.
  2. Make sure that the power outlet is receiving electricity by plugging a different device into the plug and turning the power on. If the other device does not work you likely have a blown fuse or tripped circuit breaker.
  3. Replace the blown fuse or reset the circuit breaker as needed. If it happens again, an electrician should assess the problem.
  4. Contact akai Support if Steps 1 to 3 do not solve your problem. Only a trained service technician should attempt to fix the power problem with your television
Jan 22, 2011 | Akai PT46DL10 46" HDTV-Ready Television
Hello I own an mpk 49 keyboard now I'm new at this and I can't figure out if it's internal or external sound the mpk49 gives off. Long story short how do I get the sound out of the keyboard do I have to...
You could look in the manual on Page 5 for connections to external equipment...
Connect a USB cable from your computer to the MPK49. The unit will be powered through the USB connection. Alternatively, if you do not wish to use a computer in your setup or if you wish
to power the MPK49 externally, please plug in a 6V-1A DC power adapter.
2. If you would like to use an external sound module, connect a 5-pin MIDI cable from the MIDI OUT of the MPK49 to the MIDI IN of the external device.
3. If you would like to use another MIDI controller in your setup, connect a 5-pin MIDI cable from the MIDI OUT of the controller to the MIDI IN of the MPK49.
On Page 13 the first of the FAQ's is:
Question: Does the MPK49 have internal sounds?
Answer: No. The MPK49 is a MIDI-controller, which means that it does not contain any sounds inside but is instead used
to control external sound devices, such as hardware and software synthesizers, sequencers and drum machines.
If you lack the manual you can go to retrevo.com and download it for free after you register.
Feb 02, 2010 | Audio Players & Recorders
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
Akai LCT3201AD won't turn on. Plugged in and
you have a power supply problem there are caps in the power supply that fail the will be bulged on the top these have to be replaced in most cases or a fast switching diode
or get a replacment power supply and exchange it
Oct 24, 2009 | Akai LCT3201TD 32 in. LCD Television
When i plug my akai mpk49 into my usb port it asks
me gonna hack a audition bot did not now how to hack?
May 19, 2009 | HP Computers & Internet
1,097 people viewed this question
 Grubhead
Grubhead
