Question about Video Cameras
Dew detected I have a Panasonic PV-DV2030 and Sharp VL-Z7U mini camcorders. Both of them have a dew detected error and will not stay powered on. I have tried warming the cameras up to room temp before using them, I have tried using a towel to wrap them in while they are in the bag, I have tried using a blow dryer to warm them up from a distance on low - everything I can think of. Nothing is clearing the dew error. Can anyone help me to figure out how to fix these cameras? I really need them. I've contacted repair facilities and have been told it would be cheaper to purchase new cameras. Help please!!!
    Genius:
  • 3,422 Answers
HI,
When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Just give it a good smack and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 31, 2008
  • 3,037 Answers
If you contact Panasonic, they will say to remove the tape, use a hair dryer (low setting) for about 5 minutes and then leave it opened overnight.
or you can try
to put the camera in a plastic bag with the tape door open and insert a silica gel bag (that you find in shoe boxes). Close the plastic bag and leave it overnight. The next morning, the video camera should start working! This is something that an owner tried that worked without the manufacturer's help.
Hope it works for you, too.
Let me know if you need anything else
SOURCE:
Sharp VL-Z7U cassette door will not shut - with or without tape.
Always use the camcorder with the battery and power button on.
Does the cassette compartment close without the tape ? If yes. then we have hope.
Now insert the tape and press to close the compartment as usual. Does it close or reject every time ?
If it rejects, then very slightly nudge the three tiny figures of the mechanism where the two wheels of the tape fit.
Now the tape will sit inside the compartment and lower itself.
If it still ejects, then very slightly press the base metal (where the tape rests once loaded but) without the tape. This is the largest metal piece visible closest to the hinge and door.
The tape will load properly now.
You could face error DEW or 007. Both are known errors.
DEW is really due to moisture in the air. Try on hot dry place.
for 007 error, you would need to carefully clear with one index figure the reading head. Remember all parts of the camcorder are delicate and need carefull handling.
Never use any tools, fluids, fabric or tissue.
Let me know if this solves.
I am looking for USB driver for Windows 7 and the method to extract from tape as I do not have Firewire (Ieee 1394) any more in my laptop and desktop.
Jan 06, 2013 | Sharp Viewcam VL-Z7U Mini DV Digital...
Dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Dec 19, 2008 | Panasonic PV-DV103 Mini DV Digital...
Hello...
xiii
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Oct 22, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Flashing "DEW" Indicator shutting down the viewcam
I don't know if this will help, but when I leave the camera open with no tape in it for a day or so, "dew" goes away. Now I just store it open without a tape in it and have never had this problem again.
Hope this helps.
Feb 26, 2008 | Sharp Viewcam VL-Z7U Mini DV Digital...
Dew Detected
dew detect comes from moist that gets on your dew detect sensor. This prevents any moist from damaging the tape or mech. if moist gets on your tape it will stick inside your mech. if you have not been in a moist area then the sensor could be faulty or your main pcb could be faulty.
Feb 24, 2008 | Panasonic PV-GS39 Mini DV Digital...
Dew detected on DV-203
I bought my 203 2 years ago-same problem. I FOUND THE SOLUTION! Might sound stupid, but I found it online, tried it and it works! When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew.
Sep 09, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Jun 12, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Where is the reset button on this camcorder, Panasonic PV-DV203 Mini Dv? I can't find it. Also what do it do about everytime i turn the camers on it says "DEW DETECTED EJECT TAPE" There is no...
I haven't used mine for over 2 years because of the mildew detected warning and not being able to find anyone to fix it for me. I just found this on the internet and am going to try it when my battery charges. Seems this is a common error for these palmcorders... good luck! "When you get the "Dew Detected" sign on the screen, remove the battery, give it a good palm hit on the bottom where the battery sits. Hit it a couple good times, put the battery back in and voila it will work guaranteed! I thought it was dumb at first, tried it and it works, hell it works everytime. The blow dryer, plastic bag trick dont work because its an electrical error, not actual dew."
Jan 05, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Video Cameras Logo
101 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
