Question about Toshiba CN36V51 TV
Toshiba 32A42 TV - Red Light Flashing Tech said...
We bought our Toshiba 32a42 TV in2003. Picture is fantastic. Never a problem. Went to turn on the other morning and the red light just flashes. Unplugged for 4 hours didn't help. Took to a repair shop. Says the High Voltage Transformer is bad, too expensive to fix. Your opinion? I want to make sure he just isn't trying to get my tv to fix on his own.
Corey
4 Suggested Answers
  • 87 Answers
SOURCE: TOSHIBA MODEL 32A42 will not work with remote
so does't mean the sensors working do you get anthing on the middle lead ? Thats the one that sends the data to the uP.
Posted on Apr 14, 2009
  • 541 Answers
SOURCE: I have Toshiba 32A42 CRT TV that stopped working
This unit has a horizontal/high voltage issue. This is a dangerous circuit to work with so you should have a shop check it for you. Thanks for using fixya.
Posted on Nov 11, 2009
SOURCE: toshiba 32a42. power light flashing,
usually after 4 or 5 yrs EHT ( transformer that supplies voltage to tube ) becomes weak - then TV won't get ON.. means no picture no sound but LED blinks - in some TVs along with EHT 1 or 2 components like resistor, transistors, etc will also gets deffective - so solution is TV circuit board has to be checked to find whether only EHT is deffective or other components are also deffective - price of EHT will be between Rs.250 (US$ 5) to Rs.600 (US$ 12) - iam service engineer (computers, laptops, printers,etc) - bangalore - domlur - 09986222774 - sathyavijayasarathibabu@ymail.com - if you are in bangalore then you can call me for service - i think you are living somewhere in america /australia..... - problem is simple but i don't have any idea about EHT COMPONENT 's price & service charge in your place.......
Posted on Apr 14, 2011
Testimonial: "fast response. makes sense on a 9 year old TV"
Toshiba 32A42/32A42A. Just moved tv to bedroom, worked great for 2 days, now the picture has vertical lines. Turned it off for 15 minutes, picture came on, 10 minutes later lines appear again. Anyway to...
It sounds that there is any loose solder terminals at the main board, especially with the vertical scan output section circuit. It will be best to contact any service technician to get it repaired. Gopakumar Gopalan Google
Mar 09, 2014 | Toshiba 32A42 32" TV
Toshiba model 32a42
your power supply needs to be replaced , you can do it your self
Oct 09, 2013 | Televison & Video
Toshiba 32a42. power light flashing, tv will not turn on. tried unplugging for about two hours and that did nothing.
Apr 14, 2011 | Toshiba 32A42 32" TV
TV won't turn on . Red light on front not on at all.
hi
1- unplug the AC wire
2- wait moments
3- plug the cable - if turn on lucky you. otherwise you have to bring it to repair shop
good luck
Jul 25, 2010 | Toshiba 32A42 32" TV
Clicks but won't come on, no picture
Most likely you have a horizontal/high voltage problem. There are no user servicable parts in this set and high voltage is dangerous to work with. Have a repair shop check it for you. Thanks. These are good sets so it is worth a check out.
Nov 09, 2009 | Toshiba 32A42 32" TV
TOSHIBA 32A42 WILL NOT TURN ON/OFF WITH REMOTE
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Dec 15, 2017 | Toshiba 32A42 32" TV
Kids.
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Red led blinks on / off, TV does not turn via power button and/or remote but after 20 minutes or so it turns on and works fine
Replace R902, R901, R905, R903, R900A, Q902, and possibly the two (one small and one large) capacitors in the section labeled as the power supply. The board will be black under the components that are bad. Q902 is an NPN transistor and is hard to find.
Nov 23, 2007 | Toshiba 32A42 32" TV
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
Dec 01, 2006 | Toshiba 32A42 32" TV
Toshiba CN36V51 TV Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
