Question about Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook
Motherboard I was just wondering what a comparable motherboard would be for the Vostro 1000 so i can tweak my bios....any help would be appreciated
    Genius:
  • 1,554 Answers
Laptop and desktop motherboard do not compare at all.
main reason is the power management and bios difference.
after that is the heat condition in which laptops are always hotter when running in that small of a place.
The best is to find a forum that discusses your model in particular.
the best thing to do to get more power from a laptop is to turn off power management.
run msconfig and disable all startup programs.
then disable all unnecessary services.
of which there is several sites on that .
uninstall all unneeded software, clean the registry .
uninstall the antivirus and firewall software. load firefox with protection add-ons.
then have fun.
Posted on Mar 31, 2008
SOURCE:
Ppp
If you have flashed a bad BIOS to your motherboard then the simplest solution is to replace the motherboard.
Other solutions exist, but they are very specialist and involve programming the chip using a dedicated programmer.
Apr 23, 2013 | Dell Vostro 1015 Laptop
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
How can I fixed a defective motherboard of my dell vostro 1000 laptop? where can I order the exact type of my vostro 1000 motherboard laptop?
Only Dell will be able to supply a replacement Dell motherboard.
Telephone Dell, and ask for Technical Support, to find the part-number and the (HIGH!) cost.
Jul 18, 2011 | Dell Vostro 1000 Notebook
I have a laptop (Dell Vostro 1000) which is not worked now due to motherboard problem. I want to replace motherboard of laptop. How much it cost for a new motherboard & How much it costs for second...
I would check Ebay.com or Amazon.com for prices of used motherboards. I wouldn't use a new one unless it was cost competitive with the used.
Good luck on this repair.
Jan 01, 2011 | Dell Vostro 1000 Notebook
My Dell Vostro 1000 could not start from battery. The seems to be OK, but once its in the pc, it wont start. But if I press the switch and hold it before putting in the battery it will start. Mikel from...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 24, 2010 | Computers & Internet
Same Bios Problem
Bios is always a tricky thing to do. Once you have found the bios update for that motherboard & you have double checked, then get a friend to check also or it's possible to make an expensive paperweight. Here is a site of dell products for the bios update>>http://search.euro.dell.com/results.aspx?s=gen&c=uk&l=en&cs=&k=bios+reset&cat=sup If after that you have had little success tyr calling them 0870 906 0010 or email them direct [email protected]
Hope you manage to get this sorted....
Jul 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Heard pop and dell vostro 1000 cut off and will not come back on
Based on the symptoms (Power light on cord is on when not connected to laptop but goes out as soon as you plug it in), the motherboard has to be replaced. YOu may call dell to ask about their out-of-warranty depot or you can call their spare parts sales dept to purchase the motherboard, then find a local tech to replace it.
Jun 16, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
How to overclock my motherboard ?
there are 2 ways, overclocking using the bios to over clock the memory ( ram ) and also the processor ie changing the multipliers and other tweaks ( which should be in your motherboards manual ) that or using jumpers which are physically on the motherboard but later motherboards use the bios to tweak / over clock your computer.
Apr 13, 2009 | Computers & Internet
Mother board ide ports not working
Got to MSI on line. Download the updates for all motherboard components and reinstall them. Not the BIOS, they are ok.
Go to Microsoft on line, download the current updates for the operating system and device drivers.
Go to Tweaking.com and download FREE windows repair. Now run Tweaking and although it takes time, this program helps make adjustments for you in the SAFE MODE.
See if that gets you on tract.
Feb 18, 2018 | MSI 845 PRO Motherboard
Dell Vostro 1000 Mobile AMD Sempron Processor 3500+ 60GB/1000MB PC Notebook Logo
113 people viewed this question
Ekse
Clive
Clive
