Question about Camping, Backpacking & Hiking
How do i remove the led bulb in my 3D cell Mag-lite dl
  • 283 Answers
Http://www.takeitapart.net/archives/mag-lite-2d/
Posted on Jul 07, 2010
I need the small tool to be able to get into the outer cover( the black button )to be able to change the bulb. where I can replace the bulb.
I believe you have to take the rubber cover over the button off, then push on the edges of the button, it's attached to the light assembly so you can pull it out, call Maglite tech, they'll help. Good luck.
Mar 30, 2015 | Other MAG-3D-LED - Maglite 3 D-Cell LED...
How do I replace the led in a 2w d cell maglite
Unscrew the top half of the flash light and pull the bulb straight up, and it's out,
Not to mention there's usually a spare bulb in the base of the flashlight under the spring in a piece of foam. unless someone used it already,
Line up the two pins and slide it back into the to pin holes on top and with the bottom of the flashlight back on with battery's try the on off switch and make sure it lights up and not have dead battery's, if it lights up throw away the old led and screw on the top of flashlight,
If it still don't light check for new battery's.
Oct 03, 2014 | MagLite Mag Instrument Mag Lite 2 "D"...
What is the alignment of the batteries in a 3d cell?
put the first one in positive side toward the light,, and the rest go in the same way, make sure the spring is attached to the base and screw it on, the positive side of the battery is the side with the bump on the end,, if it doesn't work after that ,, in the end cap of the flashlight you should have a extra bulb,, replace that and try it ,, be sure to put the spring back on the end cap
Aug 26, 2011 | MagLite Mag Instrument Mag Lite 2 "D"...
My mag lite led xl100 will not turn on, have fresh batteries installed
take the bottom piece off, remove the last battery and put a coating of petroleum jelly on the threads of the tube. Then take the bottom piece and run it all the way in and back off and back in 2 or 3 times. Then put a little more petroleum jelly on the threads and put the battery back in and the bottom piece. This should do it.
Apr 10, 2011 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
How do you replace led bulb in a min mag
Unscrew the lense cover and remove. Take a pair of tweezers an grasp the little buld and pull it out. Assemble it in the same manner only in reverse.
Feb 04, 2011 | MagLite Mag-Lite& Flashlight
I have a five D cell Maglite. Seems to always
There are diffferent mag lite bulbs made for different amounts of batteries. Be sure that you have the 5 cell light bulb. Also try to keep your fingers off the glass. if you get any oils on it, wipe it off before turning it on.
Also you can get mag lite specific bulbs...they cost more but they're worth it.
Feb 03, 2010 | MagLite Flashlight Type: Black D Cell 5:...
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Camping, Backpacking & Hiking Logo
379 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
