Question about Kyocera CS-2050 Black and White Copier
Photocopier got some problem with my photocopier it appears on the screen C-6 and i dont know what that means thank you
    Problem Solver:
  • 6 Answers
This Indicates a problem with the Fuser unit and will require service from a qualified technition as there are some reset codes that he wil have to enter to reset it after repair is completed.
Posted on Apr 01, 2008
SOURCE:
What is error code E000003-0002 on cannon irc 3380i
Hi . The second error indicates there is a temperature problem in the fixing unit. You need to clear that error from service mode first.
with the machine turned on Press the next:
Press aditional function once
Press 2 and 8 at the same time once
Press aditional function once again .
Service mode should appear in the screen . If doesn't repeat the secuence until it does .
Then in the touch screen
select copier
Select Function Select Clear
Select ERR and press ok in the lower corner of the touch screen .
Turn off the machine for a few seconds (5)
Turn the machine on . If problem persist that mean the fixing unit is defective
Apr 21, 2015 | Cannon Office Equipment & Supplies
Bizhub 211 reset
1-Turn the machine ON. 2-Press "Utility" button on front panel. 3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1. 4-service mode will appear on LCD screen. 5-Now with the help of arrow keys go to the last option.which is "Clear Data". (6) Now select "Memory Clear", clear the memory by clicking "Yes" or "OK" button. Wait for a while, a new code will appear on screen. Now again go to the service mode and go "ADJUST" option and with the help of arrow key select "Model setting" option and press "OK/YES" button. Now in the model setting menu select "16" which is the copy per minute speed of your photocopier machine. Select this option and press "OK/YES" . Now restart the machine.
Nov 25, 2013 | Dishwashers
C-6 400 what does it mean on kyocera KM-2020 photocopier machine
Hi my Kyocera KM2020 is showing an error code C-6 400, what does it mean and how do I fix it? Thanks
Jan 29, 2013 | Copystar CS-1650 All-In-One Laser Printer
Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
hi piz Error code P9 and P21 appears on screen and when printing or photocopying using color black, blank copies are outputed
Apr 29, 2010 | Konica Minolta bizhub C250 All-In-One...
Minolta photocopier di350 b&w what is code
Image unit code. new image unit required first try powering machine on then off. Does operator screen say Image unit needs rreplacing
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 04, 2009 | Minolta Office Equipment & Supplies
Hi!
TRY THIS
access service mode .by depressing STOP- 00 --STOP- 0 -1
and than select counter, select trouble count and scroll untel you see what that cod means .
get back to me if you need more help
Oct 15, 2008 | Office Equipment & Supplies
Canon NP6330
is requesting for identification number, use isteric 1111.
thanks
Oct 03, 2008 | Office Equipment & Supplies
Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Apr 04, 2008 | Altec Lansing ADA 885 Computer Speakers
Kyocera CS-2050 Black and White Copier Logo
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
gggg
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
