Question about Garden
PTO will not engage on my John Deere 855. Magnet
Pto will not engage on my John Deere 855. Magnet is good.
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
  • 61 Answers
SOURCE: pto clutch will not engage
ck fuses, and switch, for 12 volts
Posted on Sep 07, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
  • 18 Answers
SOURCE: PTO loads engine down and almost quits running!
pto is going bad
Posted on Jun 06, 2010
John Deere eztrak mower went over a rock today and now the mower won't engage
hmm strange are the belts driving the blades ok if so then the PTO could be damaged but if there's no sign of damage it maybe a bit frozen up/locked up have the engien off but turn the key on and engage the PTO switch and manually turn the PTO (not by the blades please....dont want to have your hand taken off) turn by the PTO itself and if you hear any clicking sound disengage the PTO and engage a few times to ensure your hearing the clicking sound of the PTO turning on and off and it should be back to normal also check any connections going to the PTO before doing the manual work of repairing the PTO
Apr 22, 2017 | John Deere Garden
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
How to repair pto on 2210 ?
Buy one, take old one off, put new one on. Be careful not to damage plugs or wires while reconnecting. If you cant do this by using common sense then you probably should have a shop do it for you. Its not very hard honestly. Good luck.
Nov 07, 2013 | John Deere Tractor Starter 285 345 2243...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
John Deere LX173 pto will not engage. Wet recently
Probably the pto switch. Find the 2 wire 'T' plug from the PTO clutch and disconnect. With a voltmeter across the the 2 spades on the tractor side of the plug you should get 12 volts DC with the PTO switch on ( you may need to sit in the seat ). If you get 12 volts at the plug its probably the PTO clutch. If no power then its a fuse or the PTO switch
Oct 24, 2012 | John Deere Garden
John deere 997 z trak pto not working,changed pto switch not help
You may have a defective park brake switch or the pto clutch could need to be adjusted.Does the machine **** down when you try to engage the pto?If so also check the seat switch.To adjust the pto clutch you need a 9/16' wrench and tur all three lock nuts on the clutch a half turn at a time a retry the clutch,keep going until it will stay engaged.
Nov 08, 2009 | Garden
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
192 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
