Question about Radio Communications
Ihave a radio shack 200 programable weather alert scanner i cant get it out of lock out please help
  • Bill Buchsbaum
    Bill Buchsbaum May 16, 2010
    What model is it? Bill B
  • 35 Answers
Press and hole the button that looks like a Key for about 3 seconds.
Posted on May 25, 2010
I don't know how to program the FRX3 so that it will sit silently until an emergency message triggers it with a tone signal or what ever they use.
Your best bet would be to obtain directions for setting up the radio. I have a Radio Shack one and it has operated very reliably although it can be unnerving to get a NOAA weather alert in the middle of the night
Feb 17, 2013 | Eton FRX3 Weather Alert Radio - Black - -
Need Radio Shack weather radio Cat. No 12-521 manual
Step 1:
CHECK OP (Check Operation) means your radio has not received any type of
SAME alert signal (include test or demo signals) for about 10 days.
Make sure the antenna is fully extended and the stored location is correct. See
"Programming Locations and SAME Codes" on page 9 for more information.
Step 2:
Here is a link to the manual
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1200521_PM_EN.pdf
Dec 06, 2012 | Radio Communications
My scanner is locked on weather alert and no buttons will work
Just take apart the scanner with a small phillips precision screwdriver and clean the pcb board of all corrosion with a dry toothbrush. And it should work like new. Shotgun 420
Jan 03, 2011 | Radio Shack Pro-82 Scanner
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
There might be a switch in the back,flip it, press manual, press L/O. hope this helps..
Mar 24, 2010 | Radio Communications
The frequencies on my scanner are not coming in
while the weather channel is coming in hi LO (lockout) so that if its programmed into a regular scanning memory it will skip. If that dont work look for a lock button or keyboard lock and press that then scan.
Mar 07, 2009 | Radio Shack Pro-95 Handheld Scanner
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
Radio Shack Pro-95 handheld scanner issues
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Jan 02, 2008 | Radio Shack Pro-95 Handheld Scanner
162.550 NOAA weather frequency
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Nov 15, 2007 | Radio Shack Pro-94 Scanner
Pro-95 dual-trunk scanner
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Communications Logo
95 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
