Hi..I am still waiting for the new dryer seals to get here so they can be replaced, but I appreciated you comments, and thought I would order the Top Center Shaft Seal part you mentioned, so that I would have it here when the repairman returns. I have the manual, and the only seal indicated in the parts and repair manual is "seal, filter cap" for the pump and motor parts section. Is that the same as the Top Center Shaft Seal?
Thanks,
Maryann
Thank
you for posting your question here on Fixya.com.
Removing
the impeller requires you lock the shaft as you turn the impeller off
counter-clockwise. You will also need to check for an impeller screw in the
center of the impeller inlet. If a screw is present they are usually left hand
thread. Back out the screw first, then proceed to remove the impeller.
To
lock the impeller you will have to remove the motor end cover or a cap covering
the shaft end depending on which version your particular motor has. Look at the
end opposite the pump and imagine a shaft from one end to the other right in
the center.
Once
you remove the cover you will see a slot for a screwdriver, a flat for a
wrench, a hex hole for a hex key or some combination of these. Lock the shaft
and spin off the impeller. Some are so tight you will end up breaking them in
the process. Simply replace it and the seal. Be sure the motor shaft is in good
enough condition to allow the new seal to work properly. If too much shaft
material has rotted away the new seal will leak soon after it is installed; you
would need a new motor at that point.
If
this answer does not fix your problem, please comment with additional details
prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is
appreciated once your problem is solved!
John
Thank
Removing
To
the center.
Once
If
John
Thank
Removing
To
the center.
Once
If
John
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. You will also need to check for an impeller screw in the center of the impeller inlet. If a screw is present they are usually left hand thread. Back out the screw first, then proceed to remove the impeller.
To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Yes, the seal has been leaking and it needs to be replaced; probably the motor bearings too.
John
John
John
John
John
Thanks, so much!
