Question about Ricoh SP 8100DN Aficio Laser Printer
How long will a ricoh sp 8100 run with a replace pm kit error code?
  • 903 Answers
On most similar Ricoh models, the "replace PM kit" message will keep flashing until the PM kit is replaced, but this shouldn't hinder operation at all. The machine will keep running until one of the parts breaks down, which depends on how old everything is and how hard it is worked.
Basically, the flashing message is a reminder to replace the maintenance kit as a preventative measure, but it does not NEED to be done until something actually breaks.
Posted on May 29, 2010
  • kpf420 Sep 23, 2010
    is there a way to reset the counters so the message stops flashing?
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
How to enter into service mode ricoh 8300dn
Ricoh SP8300 SP mode (Service Mode)
To Enter SP Mode (Service Mode)
Do one of the following:
If the power is already ON, press the "Home" and
"Simple screen" keys at the same time for more
than 3 seconds, and then press the "User tool"
key.
or
If the printer is OFF Press the "Home" and "Suspend" keys at the
same time while turning the main switch on.
Reset for Maintenance Kit A or Maintenance Kit B
So the "Replace Maintenance Kit A" or Replace Maintenance B" message will go away.
Once in SP Mode (Service Mode) press the following:
"ENGINE"
"SP-7XXX" - "DATA LOG"
"7804" - "PM Counter Reset"
"6" - "ALL CLEAR"
"EXECUTE"
Jan 13, 2014 | Office Equipment & Supplies
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
I replaced maintenance kit a and b on a Ricoh sp 8200dn, but it still tells me to change the maintenance kit on the screen. Is there an SP Mode to clear this. I tried SP5507/10 to 1 and SP 5507/11...
Off hand I'm not certain what maintnance kit is type B but you can try resetting the PM counter at SP7804
001 - Is for Paper
002 - Is for PCD (Drum / Dev unit) except developer
003 - Is developer
004 - Is Fusing
005 - Is Web
006 - All Clear
Aug 31, 2011 | Ricoh Type SP 8200 B Maintenance Kit...
How long will a ricoh sp 8100 run with a replace PM kit error code?
Normally, maintenace kit A and B are replaced at 150K copies. However, you can keep on truckin! Eventually the copy quality (blk lines, dirty copies) will degrade. Also, you might get fuser issues (error codes, jamming).
Mar 24, 2010 | Ricoh SP 8100DN Aficio Laser Printer
Ricoh SP 8100DN will not load toner
The SP 8100 is a BW printer only, it doesn't take color toner.
Mar 23, 2010 | Ricoh SP 8100DN Aficio Laser Printer
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh SP 8100DN Aficio Laser Printer Logo
356 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
