Question about Microsoft Windows XP Home Edition
Microsoft driver cannot load missing driver
Cannot load, missing driver, where did it go? Was it in the programme InCd? Anyway no use of the cd. drive now, really stuck, downloaded the system file driver, but windows won't open it, so can't install it! It is a microsoft driver version 5.1.2535.0 HL-DT-ST DVD-RAM GSA-H22N.
looked on their website, no joy, need to download and install a driver to run my cd. drive, I did a reinstall awhile ago, must have installed the Incd driver by mistake, deleted it, can't seem to recover it now.
  • garfield2 Mar 31, 2008
    Thankyou, I just saw this on the internet,
    I tried a download first and it fixed the problem, Xp Cd-DVD Fix by Doug Knox, problem solved
    Brigadier General:
  • 6,966 Answers
With the indulgence of reggieguia,
Drivers for a standard CD ROM is built-in to Windows since 3.1. There are no external drivers required. If for some reason, another software overwrote the required drivers (like your InCD?), you can try restoring your CD/DVD back in your Registry.
Go to Start / Run / Regedit
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
Value Data: [Delete All Value Data from UpperFilters and LowerFilters]
Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
Exit Registry and Reboot
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 31, 2008
    Sergeant:
    Champion:
  • 329 Answers
Have you try to format your computer? your driver seems a lower ver. and your windows driver is not a service pack 2.. try to format your computer, check all the hard drive install in your computer and it sure it will search the driver.. tnx!
SOURCE:
Missing INCD FOR DELL DIMENSION 9100
INCD is a Software needed to run CD's / DvD's... Uninstall INCD if its loaded and install VLC player..
You can download VLC player for free at http://www.filehippo.com/
Dec 14, 2009 | Dell Dimension 9100 PC Desktop
When trying to upload application programme for external dvd writer once nero 7 has been installed, message pops up saying disc is not formatted so we cannot install programme to set up dvd writer
go into add/remove programs and look for a previous version of nero. delete / remove it including incd...incd is used for cdrw and dvdrw discs. this is why you are getting format the disc. you will need to reinstall nero again, incl. incd.... also install power dvd it should be on the same disc..
Nov 23, 2009 | Computers & Internet
Disk drive ejects audio cds after a few seconds
I think that the mechanism of the cd accepter must be not accepting the cd due to blockages such as dust or sand particles. If you are experienced, open the case and try to find blockages. If problem persists, Call the company's support.
Aug 25, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
My internal cd-rom drive is shot on my laptop and I would like to install a new external cd-drive connected with usb. It will not let me download the software though. It works on one of my other laptops,...
Try loading it piggyback with another programme. Delete your old CD drive from programmes, and then load it under Vista run/progins/run/my docs It will run and put it on, but then move it from my docs to the main Icon
Aug 02, 2009 | Computers & Internet
HP external 1040 dvd writer
The Nero software came with InCD, which is a program that allows you to drag files directly onto the CD without having to run CD burning software. It's a novel idea, but I don't think it works all that well. If you're not planning to use it, then uninstall it. If you can't find it in the "Add/Remove programs" list, then you may have to uninstall the Nero software and then reinstall it but unselect to have the InCD software installed.
Jan 05, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Blue Screen of death with Re-writable CD`s and DVD`s.
First I would go to the Control Panel > System > Hardware > device manager. There go to cd-dvd drives and right click on the cd drive and then click un-install. Restart your unit then test it,
If that does not work, I would un-install InCD, then re-install it. On Nero's website there a un-installers for Nero and InCD.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2008 | Microsoft Windows XP Professional
CD-ROM icon missing on screen
Hedge,
Can you see it in your device manager? if you can't then its a physical problem which means you will need to double check your physical connections between the cdrom and your motherboard as well as the power connections.
Another way to double check is go to your bios and see if the biois detects your cdrom. If it doesnt then i think you cdrom is dead.
smeags.
Jan 07, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Nero INCD
check the properties of the cd/rw device. did the tech replace the device?
Dec 01, 2007 | Computers & Internet
Cd drive is not recognized
Hi, The problem of the CD drive missing (and sometimes the A drive likewise) has been known to come up from time to time when PCs were upgraded to SP2, on some Dell models, the InCD feature of Nero, or those with Roxio CD creator 5. A couple of things you can try: 1. Uninstall references to the CD in your Device Manager, reboot. Windows is suppose to autodetect and auto install such devices; 2. verify that the CD is detected in the CMOS/BIOS, save & exit; 4. download and merge to your registry a quickfix - 5. If installed, uninstall/remove InCD or Roxio CD creator 5. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | Dell Inspiron 2200 Notebook
Nero 6 and 7 will not load
What PC are you using?
Did you try removing ll incd software and try install?
Do you get an error message when you try to install?
May 02, 2017 | Yamaha CRW 2200E CD-RW Burner
Microsoft Windows XP Home Edition Logo
83 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
