Question about Intel Motherboard
I have a PLE01 mother board and i need to plug in the hddldd and ect plugs and i don't know how they go as i do not have the manual and cannot read the small print can u help
2 Suggested Answers
AldRezaine
  • 995 Answers
SOURCE: i have a PLE01 mother board and i need to plug in
Today's motherboard are easy to setup because mostly are now color coded like those connection ports.All you have to do is place the cables according to their color coded ports. Connectors are easy to identified because they are also labeled with name. Like the picture below.
Connections ports on the motherboard are also labeled similar to the connector cables above or have a similar abbreviated names like PSW for Power SW.
I hope this could help you..
Please don't forget to rate. Thanks..
Posted on Mar 25, 2010
Pin hookup for on/off reset switch
Go to the AOpen website (http://usa.aopen.com/index.aspx), click on download. In the drop down choose mother boards and then your model. Now if you click search it will bring up all downloads for your motherboard. Near the bottom of the list is manual, Click on the language of manual you need. Download from one of the FTP sites listed, the manual will contain a drawing of *********** board and were everything plugs in.
You can also take a flash light and magnifying glass and try to read on the mother board itself were every thing plugs in. Some motherboards have the information printed right on them, in very small mouse print.
Jan 31, 2012 | AOpen MK77M-8XN (91.88D10.031) Motherboard
Don't know where to attch all plugs for gt4016 mb
what plugs? All of them? Power supply plugs should be marked as well as different. Hard drive cable gos in the # 1 slot dvd and so on go in slot #2. If the cpu fan is installed some have a power supply plug others plug in to the mother board. Most of the time it will be close to the cpu and only a two prong plug. Most of the time all the of the wires will be marked in small writing on the plug itself and its as simple as getting a flash light and match the plug with the socket on the board that are almost always marked
Oct 21, 2011 | Gateway GT4016 Desktop PC
2001 Saturn L200 Sedan, 186,000+ miles. When first try to start it cold, engine stumbles and sometimes won't run--like its short of fuel or lacking spark. Try again and she starts fine and runs great...
You can read what the ECTS is telling your computer with a scanner. (It will read in degrees) If this is bad, sometimes it will read -40 degrees and cause the system to add more fuel, which may be you issue. Also, you can ohm out your spark plug wires to verify if they are all equal.
Jun 23, 2011 | Saturn L-Series Cars & Trucks
Cannot read cd dvd
HELLO FRIEND MAKE SURE ALL THE CONNECTIVITY CABLES BEHIND THE DEVICE IS PLUGGED IN ,AND CHECK THE PLUG SLOT ON MOTHER BOARD MAY BE THE MOTHER BOARD WILL BE FAULTY
Jan 25, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I have a PLE01 mother board and i need to plug in the hdd,ldd and ect plugs and i don't know how they go as i do not have the manual and cannot read the small print can u help
Mar 24, 2010 | Intel Motherboard
Propor place to plug in internal multi card reader
Most mother boards have an internal USB connector.
Have a read through *********** board manual it will describe all the connectors. If you don't have the manual you should be able to find it in the ASUS web site.
Also if you look really close at the Mother board and read the little white writing next to the connectors you may spot it.
I just took the lid of my pc to prove it can be done.
Mine is labled USB3 it has a block of 10 pins (male) and one is blank so it is really 9 pins. You mother board will be different to mine but have a look and see what you can find.
Sep 19, 2009 | ASUS M3N72-D nVidia nForce 750a SLI...
Looking for conection points prescott mother board (533)
Follow this diagram:
Please rate me if i am helpful to you.
Thank you.
Sep 02, 2009 | PC Chips P21G (881038000916) Motherboard
Frontal panel setup for P17G/1333 (V1.0A) mother board
I have found a manual for that motherboard at
http://static.tigerdirect.com/pdf/PCChips_P17G-1333_Manual.pdf
In general when troubleshooting this type of problem minimise the amount of problems by removing any cards and or memory - whilst still allowing the machine to function. try reseating all memory and cards as well, as these can sometimes come loose during transit.
May 26, 2009 | HP D9840-69007 - System Board Motherboard
Will not power up unless I move the display back and forth
Sorry I lost my password. This is a common problem with the 610 and other laptops. This repair is not for a Novice. Please get the maintance manual from dell go to dell support its free and know the disassembly procedures for tearing your laptop apart. Remove the bezel on top of your keyboard. The start button is on a small pc board. The problem is on the connector on the bottom of this board that commects to the Mother board of your computer. Remove all external, and plug in devices to your laptop. including the battery. After removing the keyboard, the top plastic cover, the start pc board, ect. you can see the connector from the start board that connects to the mother board. Look carefully and gently see if this connector is loose. The mother board connector is supported by 2 silver looking braces on each end. gently see if they are loose. I bet that one end has broken loose from the mother board. re solder the loose end to the mother board. be careful not to damage anything as I said this is not for the novice. (with the laptop in pieces put the startup pc board back in, temporairly put the battery in and push the start button. If the led's glow, this is where the problem is. While your laptop is apart check for dust ect. You may need to remove the heat sink , and a back support brace to get to the mother board connector to re solder it.
This has been a problem on 3 of my friends laptops Pushing on a button harder and harder doesn't solve the problem. It's not the button .Now you know the rest of the story.
http://support.dell.com/edocs/system/latd610/en/sm_en/index.htm
Hopes this helps just remember where all the extra screws go when you re assemble your laptop
Dec 11, 2008 | Dell Latitude D610 Notebook
Prescott 533 mother board power up conections to front switch
I am looking for the connection of the power button to the motherboard. Somebody plugged it out and thought it was a single plug. Now I sit with 5 plugs and do not know where to put them back and how to jump the reset.
Mar 08, 2008 | Computers & Internet
Intel Motherboard Logo
205 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
