Question about Jenn-Air 24 in. JDB1090A Built-in Dishwasher
My door will not close so that I can start the dishwasher
I have checked the trays - nothing is blocking the doorway - it seems that the lock will not release to allow the door to fully close.
    Sergeant:
    Champion:
  • 333 Answers
Sometimes the mounting screws will work loose and not allow the door to shut.Open the door now look where the top of the door hits and see if the two mounting screws have worked loose and hanging down re-tighten
Posted on May 16, 2010
My Dishwasher door keeps springing open - how do I fix this?
seems like it should have a lock on it someplace to keep door shut while operating .
May 16, 2015 | Dishwashers
While the washer is on and the water starts the door opens how to fix this? thanks
Hello Shirin;
My name is Peter. I am a retired field service appliance technician.
Push in the top and bottom trays. Close the door. Now, open the door. Are either the top or bottom trays pushed out?
In the bottom center is your water distribution vanes. Are they stuck up in the operating mode? Push the center water distribution vane down, push the top and bottom trays in, close the door and reopen. Are the upper or bottom tray sticking out? inspect the guide rails. Is there something blocking them?
So, your problem is:
1.) The trays are pushing against the door because they will not go in all of the way.
2.) You have a broken latch assembly.
You did not provide a model number. This is on a tag either on the top of the door or on the face of your dishwasher after you open the door
May 16, 2015 | Frigidaire Dishwashers
Dishwasher door does not close
Does not close or does not lock? If not locking the latching mechanism probably got loose and needs the screws re-tightened. If its not closing fully something is blocking it, loose door gasket, tray out too far, item stuck in behind tray.shelf etc.
Jul 29, 2014 | Dishwashers
My garage door will open just fine, but when I try to close it the light blinks 3-5 times and then I have to press to button and hold it until the door closes completely. what can be the issue?
Check the obstruction sensors and for anything blocking the doorway. If both sensors do not have the appropriate lights on, adjust them to get the beam across the doorway to the opposite sensor. (My units have amber and green lights on different sides. Both lights must be on.)
I hope this helps.
(we often get the sensors out of alignment when someone walks too close to the rail of the door. Weeds and bright sunshine can also interrupt the light beam.)
Jun 27, 2011 | liftmaster Garage Door 1/2 Hp
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
It seems when I pushe button to start nothing
Some fault in the dishwasher is causing it to believe the door is not locked.
I would check the door lock.
check this youtube video out for the location of the door switch.
http://www.youtube.com/watch?v=2CqFZ-Ud0nE&feature=related
(quality of video may not be the best but gives an idea of its location).
If you can give me the exact model number I can find out more details of the problem you are having.
May 12, 2010 | Frigidaire Professional Series 24 in....
The auto door is not closing all the way sometimes it opens after going halfway then sometimes it closes all the way how can this happen nothing is blocking the doorway
How long have you had this vehicle? In 2001 a recall was issued for the Silhouette concerning the latch and the motor on the powered passenger side door. Did you engage the override switch to see if you could manually open and close the door?
I strongly recommend you take your van to a GM dealer and have their service department check to see if the recall was taken care of on yoru vehicle.
Sep 10, 2009 | 1999 Oldsmobile Silhouette
How do I check/get to hinges/springs in door? Upon closing door I need to shift it to my right about 1/4 inch just before it closes. No leak.. I seems like something blocking it but the is nothing...
The door is attached by two spring loaded hinges lie on most oven doors. Pull it off. One of them is either damaged or bent. Try doing this, and if that seems to be the problem, you can find them at any local Sears or equivalent.
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Jenn-Air 24 in. JDB1090A Built-in Dishwasher Logo
124 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
