Question about Vintage Keeper Koolspace Wine Cellar
I have a Koolspace AA6 Tuscany free standing unit. Sn 05314-11. Power went out cooling unit will not restart. I get the thermostat to read and fan to turn for a while then goes into high temp alarm mode.
    Problem Solver:
  • 6 Answers
It seems like this cooling unit (AA6, also Grand Cru 800) just doesn't last as per numerous postings that I found when I was trying to find a replacement unit. Best advise seems to be get a higher output unit that will fit application.
Posted on May 19, 2010
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
I have a Koolspace 250 nuvo in my garage. It is having a hard time cooling in the summer. It is holding 68-70 degree F when set to 52 degrees. Can I make it insulated or put a fan above it to help? Can it...
You should contact Koolpace regarding this issue. They can be reached at:
Calgary Phone: (403) 283-7575
Toll-Free: (877) 283-7575
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 04, 2011 | Vintage Keeper Koolspace Wine Cellar
My Vintagekeeper Tuscany 220 wine fridge is making lots of unnecessary noise.
Hello, this is a common problem when parts start to wear in the motor. They rattle and clang allover the place, depending on age of fridge you can get the motor replaced and regassed. Or depending on age it may be time to replace the fridge. I hope this is of some use.
Nov 04, 2009 | Vintage Keeper Koolspace chillR Cooling...
Robertshaw 9600: Temperature rises too high, fan doesn't stop.
It sounds like the thermostat is wired improperly. One quick was to check is by finding breaker to unit and shutting off power. Go to thermostat and remove from wall take all wires off thermostat besides wire going to R(might be RcandRh) and C(which is common) Tape all bare wires removed with electrical tape. Now go back to the breaker and turn power back on. Nothing should be running at all. Take a voltage meter and measure the voltage from R to W(which is heating). If you read 24V then the thermostat is open and not calling for heat. Now turn the thermostat up so it is calling for heat. You should read 0V from R to W. If this checks out your thermostat is probally fine. You can check the fan the same way by going from R to G. In auto you shoul read 24V from R to G and in th on postion you will read 0V from R to G. If the thermostat checks out then the problem is probably at the furnace or rooftop. Either with the thermostat wiring or the main board acting up
Jan 19, 2009 | Heating & Cooling
Oven cooling fan keeps on spinning
Sounds like you have a oven probe or (if equipped) computer issue. From the looks of it, you dont have a computer on this model, so you probably have a thermostat stuck somewhere in there. The thermostat closes at the set temp, then opens when the unit cools. Sounds like this one is stuck in the closed position, allowing the fan to run all the time. You will have to look and see if you have a wiring diagram on the back of the unit, then find the fan wires and see which thermostat controls it. If no diagram, follow the wires out of the fan and see if on runs to a thermostat. Good luck and let me know if you need further info.
Nov 16, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Koolspace 600 Problem
You'll need to replace the fan. The original fan bearings wear our after a couple of years. It's pretty simple to drill out the rivets and replace the fan. I suggest you replace all four with ball-bearing fan units.
Sep 19, 2008 | Vintage Keeper Koolspace Wine Cellar
My Koolspace cooler in my VK250 wine fridge quit cooling
I have the same problem with mine and have tried the same things as you have. I took my unit to a air conditioner service place and they said these units are not worth fixing. It would cost about $150 to add a valve so they refill the gas and then try to find out why it is leaking. I am about to order another one which makes me vary mad. My unit is 1.5 years old.
Apr 09, 2008 | Vintage Keeper chillR 300 Wine Cooler
Vintage Keeper Koolspace Wine Cellar Logo
609 people viewed this question
Top Vintage Keeper Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Vintage Keeper Furniture Expert? Answer questions, earn points and help others
