Question about GE 46GW947 46" Rear Projection Television
My set is showing a kinda warped display where the colors won't line up. I tried the resets in the menu and it didn't help...
  • GE Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the bMy set is showing a kinda warped display where the - 69189a5.pngt fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 11, 2010
Keypad won't work sideways on my zte warp
Try resetting the device to factory defaults and that should resolve the issue. Please make sure that you have a back up of all the information and the SD card is removed before resetting it.press Menu Key > Settings > Privacy > Factory data reset > Reset phone(Don't check Erase SD Card)> Erase everything. The phone will reboot automatically.
Jan 15, 2013 | ZTE Warp
We have a Phillips plasma tv and the picture pixelates randomly and freezes for about a second and sound breaks also. We have had everything checked and have been unable to find a solution. The latest...
In my openion, Its problem of hardware in your TV and signal processing circuits are involved. It might be problem of Firmware (programe to control the performence over all) Philips can advise you better in this regard.
Aug 01, 2008 | Televison & Video
My Hitachi 57F59A projection tv has a yellow color to it. I have ajusted the color and tried to reset and start over but still yellow. What could b wrong?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 04, 2011 | Hitachi 57F500 57" Rear Projection...
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 24, 2010 | GE 46GW947 46" Rear Projection Television
I have a philips dptv305 the picture is rounded out in the corners which throws the colors off a little also in hd 1080i there is a line in the center verticaly and displays two of the same picture is this...
Convergence Problem
This is a very common failure on Projection TV sets.
Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 11, 2009 | Televison & Video
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped.
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 25, 2009 | Philips 60PP9363 60" Rear Projection...
GE 46GW947 46" Rear Projection Television Logo
53 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
