Wiring a double throw switch in a house
I have a light in my house that I used to be able to turn on from either side of the room.... there were two switches, one on each side. One was removed, now I would like to put it back and need some instructions on how to wire this correctly.
Are there any diagrams I could use so that I can put back the double throw switch and make sure it is wired correctly?
Thanks,
John
  • Josh Gahan
    Josh Gahan May 11, 2010
    ummm ? wrong category maybe?
    Scholar:
  • 35 Answers
When working with eletricity always make sure to turn the power off !!!! and test for voltage b4 you start working on the wire
here is a diagram that seems easy to understand:
http://mccarthyplace.com/hobbies/electrical/three_way_switch/
if you need help on testing the wires to find out which one is which with a ohm meter just ask
Posted on Apr 03, 2008
    Scholar:
  • 72 Answers
Simple :-)
Make yourself a checklist
1.) Turn of branch circuit breaker on panel
2.) Remove cover where old switch was
3.) I am going to make an assumption here that when the old switch was taken out the person simply BYPASSED it`s function and left the wiring in the wall...But what you should see are three wires. Two will be wire nutted together and the other will be all by itself.
4.) Look at the new "3-way" switch that you have bought. It will have 2 brass colored screws and one black colored screw.
5.) connect free wire to one of the brass screws
6.) disconnect wire nutted pair look for same colored wire that the free wire was. Then connect that to the other brass screw.
7.) the remaining wire will go to the black screw
8.) Now before you power anything up, remember I made assumptions above but you can go to the other switch on the wall pull that out and check a couple of items. The two wires that are connected to the BRASS screws need to be the same two wires that you connected to the new switches BRASS screws. I don't know if you have conduit or BX or romex so you will have to keep track of the wire colors. The wiring between two 3-way switches are shown in the attached pic. Let me know if it works....:-)
Posted on Apr 30, 2009
I have a 2005 325ci bmw the hazzard light not working neither turn signal .
The simple, and most likely, cause of this problem is a blown fuse in the turn signal circuit. Normally, the turn signal lamps are activated by a single-pole double-throw switch circuit on your 325ci's steering column. That switch is also called turn signal switch and, as you know, you activate it by pressing up or down on the turnstalk (the lever usually on the left side of the steering wheel).
The hazard light circuit is a double-pole single-throw circuit that gangs the right and left turn signal circuits into one and then activates the front and rear signals as your 325ci's hazard lights.
Since they use the same circuits, the fuse is common to both and if it is blown then neither the turn signals nor the hazard lights will work.
Jan 03, 2015 | Cars & Trucks
Out of the blue, the power is gone in a couple of rooms in the house, I checked the breakers and they are good. any ideal?
There are many possibilities if you have an older house like mine there are two horizontal aluminum or copper bars all the breaker switches are hanging from Careful push and or jiggle the breaker that is responsible for dead rooms If lights flicker the breaker is probably over loaded and bad as well as cooked that spot on the horizontal mounting hot plates I say hot cuz of main is on they are powered If this is case you need to split the rooms onto more breakers and not use the burned spot that is where you current switch is this is not up to code but if what Im saying is right neither is your house and it will keep you from burning down Side question had your power been flickering in those dead rooms before complete outage Brownouts If yes this backs my thoughts
Jan 16, 2014 | Electrical Supplies
One light stays on 2lights one switch
check wiring to switch the light that stays on must be wired to the wrong side of switch. disconect both wires from both lights and double them up and reconect them where the light that turns off was wired
Jun 27, 2013 | Cars & Trucks
Replacing a triple single pole (1980's) with a
DISCLAIMER:Attempting to work on house electrical systems without proper training is DANGEROUS and you stand the risk of dying.
The Cooper 7729w is a three pole single throw switch with a common (connected) hot wire that supplies it. What you had before was two separate single pole single throw switches and one single pole double throw switch that is used as a three way. The short answer is NO that replacement will not work UNLESS you don't want the other switch on the other side of the room to work.
Personally, I think that if you really need to ask this question you need to seek the advice of a professional electrician.
Dec 18, 2012 | Electrical Supplies
How to wire a double light switch
The neutral never connects to a switch.
The switch turns OFF hot wire to each light, while the neutral remains continuous throughout whole house.
The neutral is like the ground wire in residential single-phase wiring: both remain unbroken and continuous throughout house.
Copy following link for double switch wiring diagrams, including boxes with neutral wire and boxes without neutral wire:
http://waterheatertimer.org/How-to-wire-switches.html#double
Aug 15, 2012 | Electrical Supplies
How do i wire in a 2 light colour signal to a 2 way switch
Two Way Light Switch Wiring Have you ever wonder how a lamp that is used to light up the stairs of a building is connected to the two switches that controls it from either end? These two way switches have a single pole double throw (SPDT) configuration. Each has a common terminal (COM) with a pole that can be switched between position L1 or L2. The two way light switch wiring can be implemented by using 2 different methods. Both of the methods used are described below.
The first method as shown in the figure above have the COM, L1 and L2 of both the SPDT switches connected together. For incandescent lamp, the recommended wire gauge used is AWG #18. The LIVE AC Source is connected to L1 of SW1 and one side of the load is connected to L2 of SW2. The other side of the load is then connected to NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is at ON position and the other is at OFF position. If both switches are in the same position, the lamp will be OFF.
The other method is as shown in the figure above. In this configuration, the L1 of both SW1 and SW2 are connected together. Similarly, the L2 of both SW1 and SW2 are connected together. The LIVE of the AC Source is connected to COM of SW1 and one side of the load is connected to COM of SW2. The other side of the load is then connected to the NEUTRAL of the AC Source. With this configuration, the lamp will be turned ON when one switch is ON and the other is also ON. If both switches are in different position, the lamp will be OFF.
Take note that as the installation involves mains power supply, only those who are qualified and have electrical wiring knowledge should do this wiring. When doing the wiring, it is recommended that the power supply is disconnected from the load and the switches.
Nov 13, 2010 | Computers & Internet
Throwing the breaker .had the oven for 6 weeks working fine now turned on the upper oven and the breaker threw. the house/wirting is only 10 years old?
You have a problem in the oven not in the house wiring...you probably have a bad element in that oven and it is shorted...this throws that breaker when you turn it on...
heatman101
May 06, 2010 | Whirlpool GBD307PDS Electric Double Oven
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Computers & Internet Logo
1,256 people viewed this question
David Payne
David Payne
