Question about Pool & Spa
Pentair sm2-pp3 valve, triton II filter. Upon
Pentair sm2-pp3 valve triton ii filter. Upon backwash...sand is blown into pool. Through air jets. system is two years old
  • 8,404 Answers
Lots of sand? You may have a broken lateral in your filter.
To repair, you will have to remove all the sand from the tank to physically inspect.
Might you have changed the sand this year? (top 1/3 needed to be changed every 3 to 5 years normally) If you changed the sand ... did you put water in the filter tank first? If not ... there is a good possibility you broke a lateral (a small pipe with slits in it) when you put the sand into the filter.
It could be that you have too much sand in the filter. Check the owners manual for the clearance - top of sand to top of filter.
Thanks for your interest in FixYa.com
Posted on May 16, 2010
Lets try again. Old triton sand pool filter. Two orange valves. What position should they be when filtering and what position when backwashing
if the pipe after the tap goes back to the filter then when that tap is on the water is going through the filter
the line after that tap goes to a drain then that is backwash tap
contact a pool cleaner to get a better explanation
Sep 09, 2015 | Pool & Spa
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
Old triton pool sand filter....2 orange valves.. What is the position for filtering and backwashing?
orange valves are for the returns the backwash is the skinny rod with the black handle check flow of pool I think up is backwash down is filter
Sand shooting back in pool
If you took "Pump" apart, you wouldn't have found broken laterals. You will need to open up the "Filter" to find laterals. If sand is ending up in the pool, you either have a broken component within the filter or you have an overfilled filter tank and during backwash sand is lifted up into the valve, and upon returning valve position back to "Filter" the residual is blown back to pool via the return inlet. If this is the case that is why always follow label / owners manual directions as to Quantity of media to add. More is not necessarily always better!
Jun 19, 2014 | INTEX Sand Filter Pump
How to replace the gasket on a sm2-pp3 multiport valve assembly
make sure you note the position take a picture remove screws holding top of multiport on lift off there is the gasket clean off some have to be glued back on then put back together
Oct 06, 2012 | Pentair 112 Multiport Valve Kit for FNS...
Pentair sm2-PP3 multiport valve assembly
note position or take picture before taking apart then remove top screws take off top remove old gasket install new one careful some have to be cemented into place
Mar 18, 2012 | Pentair 112 Multiport Valve Kit for FNS...
Sand and murky water being discharged into pool after backwash
You posted this question in Alarm category. but sounds like either your filter laterals, or the backwash valve are bad. I'd need to know what type of filter, and backwash valve you have. is the backwash valve a multiport, or push/pull slide valve, etc... If it's a push/pull valve then the o-rings, or pucks can be bad, or the piston can be broken. if it's a multiport valve, then the spider gasket may need to be replaced. if it's a top mount multiport valve, then it can be broken inside the filter.
Aug 16, 2010 | Pentair Pool & Spa
Pentair Quad DE system was installed without multiport valve
This is a DE (Diatomaceous earth) IT doesn't have sand and doesn't backwash. You use the bump handle (with pump off and valves closed and vent open and drain dirty water/earth out) Here is a link to the manual for your filter If isn't the exact model they are all on their web site: http://www.haywardnet.com/products/Manuals/pdfs/manual9.pdf
Jul 20, 2010 | Hayward EC-40 DE Pool Filter with pump
Pentair sm2-pp3 valve, triton II filter. Upon backwash...sand is blown into pool. through air jets. System is two years old
Sounds like you have a problem inside the filter. This will probally be something you will want to get a pool guy for. If the filter is only two years old you should check for warrenty on the filter. Sorry for the bad news and good luck.
Mar 24, 2010 | Pool & Spa
Sand from the filter is getting into the pool.
u are getting sand in to your pool most likely because u have a broken lateral i nthe bottom of your filter.
Jun 07, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
556 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
