Question about Maytag EPIC MFW9600S
Front Load Washer Seal
The sleeve of a shirt got twisted and wrapped around the rubber seal. It pulled the seal and the circular metal band out. I need a picture guide of where the metal band goes so I can put the seal back in.
    Genius:
  • 1,554 Answers
You will have to take off the front off washer to put it back correctly.
remove the top panel 3 screws in top rear
remove the bottom panel 3 screw in bottom front
remove the top led control panel 3 screw or more along front lip
if you disconnect any wiring mark it well .
now the front of washer can be removed with or without the door (your choice)
careful with the door lock wiring.
be sure to unplug the washer.
while you are in the innards its a good time to wipe around the drum any buildup of soap etc..
and to clean the filter trap in the bottom access tube below drum.
Posted on Mar 31, 2008
Front seal came off
Sometimes when the load get tangled during the cycle and you try to pull all the load out in one go, you can dislodge the seal and retaining spring. Remove the wire around the door seal, repositioned the seal around the edge of front panel porthole. There is a folded metal edge around the metal frame and the grey rubber gasket lips over this, once in position, offer up the metal retaining band and use a pair of long nosed pliers to stretch the spring so you can get it to sit around the seal. Sorry this a little long winded but very difficult to articulate properly, so I hope you get the gist. Cheers
Mar 26, 2013 | Bosch Washing Machines
We have a Whirlpool frontloader washer. The rubber tube on the inside of the washer has come off and the metal band the keeps it in place has snapped off..IT looks like it would be and easy fix. I am...
This page should help http://appliancehelponline.com/washerdoorseal.html
There are 2 metal bands 1 goes around the seal at the front panel the other around the outer tub to seal. On the whirlpool the seal is a little tough to get at without removing the counter weights but it can be done.
May 27, 2010 | Frigidaire Affinity ATF7000E Front Load...
Rubber door seal has disconnected
if the wire in the seal is propely positioned and not slightly askew it should work OK But if it looks correct and leaks you will need a njew seal as it may have been bent or stretched
Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Circular grey rubber part ..
firstly u have to take the wire off it with a screwdriver unscrew it take it off then watch how the old on pulls off as there is a lip all around this rubber and it as to bed into the metal drum just see how the old one comes off once you have put the new one on put the wire back around it or it could be a metal strat wich tightens up with a screwdriver,rgds,paul
Jul 07, 2009 | LG WM-1832C Front Load Washer
The door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
shaun
Mar 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
My husband was washing a load of clothes and as our front load maytag washing machine started to spin, a shirt wrapped itself around the rubber part that is at the front of the washer and pulled it out and...
you will have to take off the front off washer to put it back correctly.
Mar 31, 2008 | Washing Machines
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Maytag EPIC MFW9600S Logo
231 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
