Question about Tomtom One Europe v2 GPS Receiver
TomTom One bluetooth phone pairing doesn't work
I have a TomTom One bought in USA, so 2nd Edition I suppose. When I tried to pair it with my Samsung BlackJack II smartphone (bluetooth visible turned on), it found the blackjack phone fine, but when connect, it doesn't make the passcode prompt appear on the cellphone, then quickly it says there are some feature that is not available on this cell phone.
Tried with a blackberry 8803, same problem. Are these problem real or is there any hack available to pair the phone and TomTom One GPS?
  • 1 more comment
  • Samir_Patel Apr 09, 2008
    I am having the same problem with the TT1 and the BJ II. There is a message on the TT1 which indicates that there is only a Voice Gateway (only appears for a moment); it then goes to the error screen.
    When I paired the BJ II with my computer, I found a voice gateway & a OBEX Object Push.
    I used to use the TT1 with a Nokia E62 (which paired fine). For the E62, I found the following on my computer:
    - Dial up networking
    - Imaging
    - OBEX file transfer
    - OBEX object push
    I suspect that the BJ II bluetooth stack doesn't have necessary support to allow for it to pair to the TT1.
    Would appreciate it if anyone has any further info on this.
    Thanks.
  • Anonymous Jun 17, 2008
    I have a Samsung SPH-M500, it find the device TOM TOM ONE XL but
    when I go to add it to the list, it wants a PIN I tried 000 and 1234 but
    it doesn't work. On my TOM TOM ONE XL it doesn't search for my phone.
    Please help....
  • Anonymous Mar 30, 2009
    I have the same problem with the Samsung Wafer. My TomTom sees it but will not connect to it via bluetooth saying the phone does not have th required features... Can any one help???!!!
Vfdsvgbsdgsdfg
Posted on May 15, 2008
I'm not sure if this helps but i have a samsung sgh-a516 and at first all i could pair with my phone was wireless (the one feature i will never use). Randomly i get a phone call on my cell with my tomtom on and somehow spontaniously it just decides it wants to connect via handsfree? I was playing around in the tomtom options today and in preferences i selected send file (at the very end of choices in the menu) and tried sending a song from my tom tom to my phone it took 2 trys but finaly it found my phone and sent the file , i refreshed the bluetooth service list on my phone and sure enough object push was added i then deleted my phone from tomtom and repaired it. needless to say i can now trasnsfer my contacts and talk handsfree when in the beginning my 920 would only recognize a wireless service. All i can say is try and play around with settings on both devices and you might be in luck and trick them to work. I hope this helps
I've bought a used car with fitted Parrot CK3100. When trying to pair with my Nokia 6230i, I manage to locate the Parrot. When I press the 'Pair' command, I'm told to enter the code, but before I can even...
before jumping into updating or flashing the software of the unit we may try few steps to get it working.
try this one:
on the parrot go to settings
advanced settings
pair with phone....
(on your phone...search the parrot.)
set the pairing using the "1234" password.
if that doesn''t work
try to push the red the green and the wheel.(this method will reset the CK1300) whne pushing do not let go until the screen changes display, may take at least 3-5 seconds.
after this try the pairing once again.
hope this helps, good luck
Aug 02, 2008 | Cell Phones
Not pairing with other devices
Have you turned blue tooth settings on your phone? Also you can pair your phone if the Bluetooth is working. Otherwuse you may be out of range. If that does not work have someone else try the bluetooth to eliminate the problem is with your phone.
Nov 15, 2013 | Cardo Scala Rider Teamset Pro
I have a samsung genio touch n cnt work out how to delete paired bluetooth devices n i cnt connect to any1 else until i delete some!
Follow this path- main menu-> bluetooth (its in the 2nd homescreen)-> turn on bluetooth (by tapping on the icon). This should show all the devices paired with your phone. Find the device you want to delete and tap on it. select 'delete' from the options shown
Mar 19, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Samsung WEP 450 was working ok for its 1st 24 hrs paired with Samsung B2100, however will not connect now. I've gone through the pairing up process again and the device cannot be found. The only other...
normally, the pairing has to be done once. If successfull, you can not pair the device a 2nd time withou removing it from the "paired devices" list in your phone. In order to get it recognized you should do the following.
1. check that BT is off on both devices
2. turn BT on on your mobile phone
3. power on your headset. In case, you have paired the headset successfully before, it has to be registered in your phone. It should then automatically find for the paired device (your phone in this case) and connect.
Dont try to power on the headset before turning BT on on your mobile phone.
If you have no success try to navigate to the bluetooth settings, check "paired devices" and make sure that your headset is deleted. Do the pairing and the 3 stepps above once again.
Don forget, that the headsets also have to be charged..
Jan 13, 2011 | Samsung WEP450 Bluetooth Headset - Retail...
MY HEAD SET HAS NO CONNECTION WITH THE DEVICE (TOM TOM RIDER 2ND EDITION). THE DEVICE CAN NOT FIND THE BLUETOOTH HEADSET
Reset the unit by pressing the small pin hole button. Do this when the unit is on. let it reboot by itself and try again to pair ur phone/blutooth.
Hope this helps. let me know if not.
Aug 11, 2010 | Tomtom RIDER 2nd Edition GPS
I could not pair my telus samsung phone with the tomtom 730
Is bluetooth enabled on both devices?
Do both devices detect each other?
Have you entered the bluetooth access code correctly?
What else have you tried, and what's the model number of your cell phone?
Nov 04, 2008 | Tomtom GPS
Wireless data connection
hi!!!!!!!!!
try to configure out first the router!!!!
may be it has network password or security key
Sep 23, 2008 | Cell Phones
Tomtom One Europe v2 GPS Receiver Logo
1,793 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
