Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Hamton Bay Ceiling fan w/ remote.
My remote does not seem to function, the fan stays on the brightest and highest fan speed. Ihave changed the batteries, any suggestionns??
  • Anonymous Oct 08, 2008
    i dropped the remote is it a good chance the remote isnt in sync any more or the numbers jumped
    Problem Solver:
  • 7 Answers
The remote and the transmitter have 4 keys to set the frequency that each r on. (In case of multiple fans and remotes) The keys above the fan have to match the keys in the remote. It is a simple up or down position for each. They r small. but if they dont match, they r speaking different languages.
Posted on Jun 12, 2008
Bent ceiling fan blade brackets
This is what you need to do:
So how do you contact the Hampton Bay Replacement Parts Department?
Simply call 1-877-527-0313 then select option #2. This department will then help you find the replacement part you need for your hamton Bay product.
Dec 23, 2012 | Dryers
Looking for a hamton bay ceiling fan remote control. Model # is 54chrol and the price
Phone Number for Parts and Customer Service for Hampton Bay Fans is at the bottom of this page. Thanks!
Sep 22, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Ceiling fan stuck on low
in order for the remote control to work properly the fan has to be on its highest speed using the pull chain ... after setting the pull chain in the proper position you can tie up the chain or remove it to prevent others from changing the setting .. the remote will control the speed from then on ..
Jun 07, 2010 | Hampton Bay 24002 Ceiling Fan
I have a ceiling fan with remote, remote will not turn fan on high, how can i fix this
The fan probably has manual pullcord switches - one for the light and the other for fan on/off/speed. The fan control pullcord needs to be at maximum setting.
Switch the fan on using the remote. Then set it to high using remote.
Now use the pullcord switch (probably cycles through off, low, medium, high, off with each pull). Set it at its fastest speed, and leave it there.
You should now be able to select highest speed from the remote.
Happy to try to help more if that does not work.
Feb 25, 2010 | Hampton Bay 24750 Huntington III Ceiling...
My Hampton Bay 54shrl which has two wires only an a remote,the problem is the remote seems to work find and then it does'nt I disconnect the wires reconnect and then it works for a while I'm Baffled can...
We have four models range 54SHRL Hampton Bay three of which face problems in speed. We try to raise it in the remote and just stay at the slower speed. What can we do?
Jul 06, 2009 | Hampton Bay 52 In. White Redington...
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Jun 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan only running at highest speed
First, change the battery.  Second, turn off the power to the fan at the wall switch, if still installed.  If this doesn't fix it, it is probably dead.  Bring it back to Home Depot.  There may be a product bulletin.
Nov 14, 2008 | Dryers
Remote Control
Change the remote control batteries. Because of the motor construction, it needs to turn on in the highest speed setting. This is why it defaults to the high speed mode. Put new batteries in the remote and that ought to fix it.
Mar 04, 2008 | Hampton Bay 48670 Flemish Pewter Finish...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
497 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
