Question about D-Link DIR-615 Wireless Router
Connected but internet says diagnose connection
Have installed the D Link router, set up a password etc and have entered this network key. The wireless says connected but the internet page will not come up and says diagnose connection problems
  • 2,260 Answers
Is there any computer able to access the Internet ?
If this is the only computer then connect the computer to the router with the cable and see if it works.
If you are able to access the internet with the cable connected to the router and computer then then the wired part is working. Check the wireless settings of the router. Also make sure that there is no static IP address set up on the wireless network connection.
Posted on May 17, 2010
  • Prashant M
    Prashant M May 17, 2010
    Click here for more information about
    the router and wireless network
HOW TO I GET MY WII TO CONNECT TO THE INTERNET
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection Settings."
5.Select "Connection 1: None."
  • If you do not have an empty connection slot, you will need to clear a slot.
6.Click on "Wireless Connection," then click "Search for an Access Point."
  • If using a wired Internet connection,
7.Select "OK." The Wii will display all the wireless networks it finds.
8.Select the wireless network that is yours.(If you're not sure which is yours, or you don't see any wireless networks)
Asked to enter a security key?
  • If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  • If you need to switch between upper and lower-case letters, or numbers and symbols, select the "Shift" key on the on-screen keyboard.
  • Ensure you review the security type in the top-left corner as well. If this is not the same security type that is used by your router, select "Change Security Settings" and select the appropriate security type.
9.Select "OK" 3 times to save your settings and start an Internet connection test.
  • The Wii console will run a connection test with your wireless network.
  • When the test is completed, you should see the following screen:
  • If the connection test succeeds, then your Wii is now connected to the internet.
  • The connection test was not successful, you will receive an error code.
    • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step eight (8) above for more information.
Don't know your routers security key?
Here's some:- A..To login into your Linksys router:
  1. go on this link: http://192.168.1.1
  2. The default username is: (leave blank)
  3. The default password is: admin
  4. Look for the security key settings. For Linksys routers, they are usually in "Wireless Security" on the "Wireless" tab or something similar.
  5. Find the selected WEP or WPA key, and write it down. Enter this number into the Wii or Nintendo DS when prompted.
B. To login into your Netgear router:
  1. Go on this link: http://192.168.0.1
  2. The default username is: admin
  3. The default password is: password
  4. Look for the security key settings. For Netgear routers, they are usually in "Wireless Settings" on the "Setup" tab or something similar.
.C.To login into your DLink router:
  3. The default password is: (leave blank)
  4. Look for the security key settings. For DLink routers, they are usually in "Wireless" on the "Home" tab or something similar.
Aug 18, 2017 | Internet Computers & Internet
Problem with D-Link 1360 n access point. Not able to visit ip address 192.168.0.50
The internal Wi-Fi radio is enabled by default on most new wireless routers.
However, if you purchased a D-Link router used, you may find that the internal radio is disabled because the previous owner had an exclusively wired network and wanted to eliminate the possibility of a hacker breaking into one of her computers.
Enable the Wi-Fi radio on your D-Link router to enable your computers to connect to the Internet wirelessly.
Connect the router to your computer using an Ethernet cable.
Open a web browser and browse the IP address "192.168.0.1."
Enter the username "admin" and leave the password blank.
Note that these are default values; both the user name and password can be changed.
Click the "Setup" tab at the top of the screen, then click the "Wireless Settings"
Scroll to the bottom of the screen and click the "Manual Wireless Network Setup" button.
Place a check in the box labeled "Enable Wireless" and click "Save Settings."
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamationmark! or a red Xright click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
If you cant install the driver
Make sure you Ethernet/internet is enabled in biosrestart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigateto integrated peripheralslook for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
D-Link Wireless Router
D-Link routers use the connection from your Internet service provider to create a wireless network for the various Wi-Fi- enabled devices in your home or office.
Once the router is installed, you can truly enjoy the portable capabilities of your laptop or other wireless device.
D-Link routers have a straightforward installation process, despite the advanced technology behind wireless equipment. So there is no reason to wait around for a technician to help you install your wireless equipment. Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in.
This will reinitialize your modem and force it to establish a connection to the D-Link router.
Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser.
Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field.
Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network.
Click "Apply" to save the changes to the router's settings.
Network D-Link wireless
Type the router IP address, "192.168.0.1", into your Internet browser. Press "Enter" on your keyboard.
Enter your username and password to log into the D-link configuration panel.
By default, the username is "Admin" with a blank password field.
To prevent outsiders from being able to access your D-link router's configuration panel, change the username and password to something more secure.
This can be done by selecting "Tools" from the menu and selecting "Admin."
Select "Administration Settings" and enter your new username and password.
Save your changes by clicking "Apply."
Enter the IP addresses for the computers you want to give access to your router.
You can do this by clicking the "DHCP" link underneath the "Home" tab.
Click "Apply" to save the IP addresses.
Select the "Wireless" link underneath the "Home" tab.
Enter a name in the "SSID" field to identify your wireless network.
Choose "WPA" for your "Security" option.
WPA will provide the highest level of security for your wireless network.
Create a WPA password to access your wireless network.
For maximum security, enter a combination of numbers, letters, and symbols.
Store your password in a safe place in case you ever forget it.
Click "Apply" to save your settings.
Install a software firewall program on your computer to add an additional measure of security for your wireless network.
A few of the popular firewall programs available are Norton Antivirus, McAfee and Zone Alarm.
Mar 18, 2014 | D-Link Wireless N Access Point Dap-1360 -...
Only lights stnadby lamp
Turn on the Wi-Fi on a D-Link Router
The internal Wi-Fi radio is enabled by default on most new wireless routers. However, if you purchased a D-Link router used, you may find that the internal radio is disabled because the previous owner had an exclusively wired network and wanted to eliminate the possibility of a hacker breaking into one of her computers. Enable the Wi-Fi radio on your D-Link router to enable your computers to connect to the Internet wirelessly.
Connect the router to your computer using an Ethernet cable. Open a web browser and browse the IP address "192.168.0.1." Enter the username "admin" and leave the password blank. Note that these are default values; both the user name and password can be changed. Click the "Setup" tab at the top of the screen, then click the "Wireless Settings" Scroll to the bottom of the screen and click the "Manual Wireless Network Setup" button. Place a check in the box labeled "Enable Wireless" and click "Save Settings."
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc If you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima D-Link Wireless Router D-Link routers use the connection from your Internet service provider to create a wireless network for the various Wi-Fi- enabled devices in your home or office. Once the router is installed, you can truly enjoy the portable capabilities of your laptop or other wireless device. D-Link routers have a straightforward installation process, despite the advanced technology behind wireless equipment. So there is no reason to wait around for a technician to help you install your wireless equipment.
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem. Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet. Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router. Your router will immediately begin distributing a wireless network with the "D-Link" network name. Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser. Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field. Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
Network D-Link wireless b> Type the router IP address, "192.168.0.1", into your Internet browser. Press "Enter" on your keyboard. Enter your username and password to log into the D-link configuration panel. By default, the username is "Admin" with a blank password field. To prevent outsiders from being able to access your D-link router's configuration panel, change the username and password to something more secure. This can be done by selecting "Tools" from the menu and selecting "Admin." Select "Administration Settings" and enter your new username and password. Save your changes by clicking "Apply." Enter the IP addresses for the computers you want to give access to your router. You can do this by clicking the "DHCP" link underneath the "Home" tab. Click "Apply" to save the IP addresses. Select the "Wireless" link underneath the "Home" tab. Enter a name in the "SSID" field to identify your wireless network. Choose "WPA" for your "Security" option. WPA will provide the highest level of security for your wireless network. Create a WPA password to access your wireless network. For maximum security, enter a combination of numbers, letters, and symbols. Store your password in a safe place in case you ever forget it. Click "Apply" to save your settings. Install a software firewall program on your computer to add an additional measure of security for your wireless network. A few of the popular firewall programs available are Norton Antivirus, McAfee and Zone Alarm.
Jan 28, 2013 | D-Link DIR-600L Wireless N150 Cloud Router
After cable co. split cable and installed another modem, D-Link WBR 2310 router no longer works with its original modem. Tried resetting, unplugging, etc. Can't get wireless.
Use an Ethernet cable to connect your computer to one of the LAN ports.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 123.468.32.1
Start Internet Explorer
Type http://123.468.32.1
Press Enter
Login to your router
Click to run the "Wireless Networking Setup Wizard", to:
1. set an SSID
2. set an encryption-level, e.g., 'WPA' or 'WPA2'
3. set a password for your network
Click OK to restart your computer
Use your wireless device to connect to that SSID, using that password that you set.]
Jun 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Hot to secure my router from my neighbors using them. thanks
click this link to open the router login http://192.168.1.1/
When asked for username use admin and password leave it empty
then goto
SETUP -> WIRELESS SETUP -> MANUAL WIRELESS CONNECTION SETUP -> WIRELESS SECURITY MODE and select "Enable WPA > WPA -> WPA Key -> create your own password and save now if you want to access the Wireless connection you will have to enter the WPA key you just created.
Apr 11, 2011 | D-Link DIR-600 Router
There is no wireless connection and it says that the password may have been changed. It also asks for the key to be entered. What is the network key? How do I change it? How do I restore the assigned...
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here
for step by step instructions
Apr 12, 2010 | Linksys WRT160N Wireless Router
Where do I find my WEP key
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your change
Nov 21, 2009 | Linksys Wireless-G WRT54GS Router...
Lost install cd for netgear wndr33oo
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Jul 08, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
ROUTER INSTALLATION AND CONFIGURATION
connect existing modem to the router
reset router (located at the back)
connect computer to one of the 4 ports of the router
run internet connection wizard & choose "computer is connected to a gateway / internet connection is always ON"
for wireless:
connect a computer to the router hard-wired
for your router, open a browser and access 192.168.1.1
leave it blank for the username and admin for the password field
click wireless tab, change the Wireless Network Name (SSID):
click save settings
next click Security Mode: and choose WPA2 Personal
make a password in the WPA Shared Key: field
click save settings
on the computer, go to view available wireless network & click the wireless network name you made, connect, enter password when prompted.
good to go
Jan 24, 2009 | Linksys Wireless-G Broadband Router
"security key/pass phrase"
Yes, it will set it all back to factory defaults
to set the security again on the router Support site for D-Link is here http://www.dlink.com/corporate/worldwideoffices/?redirect=/default.aspx In principle: Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - http://192.168.0.1 Enter (admin) for the user name and also for the password. Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --------------- Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Dec 19, 2008 | D-Link Wireless
D-Link DIR-615 Wireless Router Logo
154 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
