Question about T-Mobile MDA
MDA Problem Thanks for the info. So far everything has been working normally. It doesn't seem to need a new battery right now. I have no idea why it stopped working for about three weeks, but we are good to go!
Oh yeah your welcome. i loved my MDA which is y im trying to find one on ebay! lol it really has been the best phone ive owned. ive tried blackberry and a few nokia smartphones but none can quite compare to the MDA! the only problems ive had with it were the battery the phone completely stop working and when it did work it kinda bothered me that active sync and other programs would automatically start for no reason but wouldnt show up on screen they would just be running and would slow the phone down and i would have to check every couple of hours or so in running programs to see if anything unneccessary was runnning. but other than those few problems its the best phone i believe!
Posted on Mar 31, 2008
SOURCE:
Damage after batterie replacement
Take it to a qualified profession to repair.
May 02, 2013 | Apple iPhone 4S
My kodak dcs pro slrc menu doesn't work and the camera seems locked up. Any idea?
Hello Dana, Remove battery and fully charge or replace with new, then try to start camera again. If camera does not reset itself it will need serviced/repaired.
Dec 07, 2012 | Kodak Cameras
My Sloney E reader doesn't seem to be taking a
Because the battery is not removable? Best thing is to allow the E Reader to be completely cleared of any charge. OR While it is plugged in, press and hold the power and N buttons simultaneously for 20 seconds. I then turned the device on normally. Hope this help, have a great day..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Feb 24, 2012 | Sony Computers & Internet
Torch Windrider 10 won't start showing speed, etc. relevant data seems to have been stored successfully
I have a Torch Windrider Cycle Computer 10 and the Power Auto doesn't work - that is it will not turn off. I have tried everything, new battery, resets etc.
Any ideas anyone.
Thanks - David.
Jul 26, 2010 | Cycling
Manual transmission will not go into reverse
Behind the battery where the cables connect there is a part called a carrier 1J0711256...less than [email protected] vw dealership...easy to install...remove breather...take bottom cable loose...put part on
Sep 27, 2008 | 1999 Volkswagen Beetle
Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
May 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
T-Mobile MDA Logo
114 people viewed this question
Top T-Mobile Computers & Internet Experts
Ekse
Marvin
Marvin
markpain
Level 1 Expert
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
