Question about Samsung CLP-600N Laser Printer
Samsung CLP600 - wants me to install a transfer belt
Samsung CLP600 printer, shortly after changing black toner, says INSTALL TRANSFER BELT even though I haven't removed the existing one. Any ideas?
  • 4 more comments
  • buck65 Mar 31, 2008
    Good thought -- but I don't think I've changed anything at all. It's nowhere near 50,000 copies -- probably not even 2500 so far since I've owned it. How can I make sure the belt is in place? I'm trying to find the sensor for it...perhaps it is dusty.
  • andrewksu Sep 09, 2008
    Same deal, new transfer belt results in same error and no printing,
  • willybfree Sep 17, 2008
    same problem...bought and installed new transfer belt and error message continues.."install transfer belt"...any ideas how to fix this????
  • dongphamp Oct 15, 2008
    Hello, I have the same problem, got "install tranfer belt" and dont know how to fix, hope someone can show me the best way to solve the problem, please help !
  • Anonymous Mar 27, 2009
  • akrama Apr 29, 2009
    I have this problem, I have samsung clp-600n. I have just replaced the transfer belt on the printer but the displays display show to replace the belt. what am I doing wrong?
"install transfer belt" message" appeared right after black toner was relpaced with a non samsung toner(new chip too)--installation of new transfer belt did not solve problem--- i went back and reinstalled the original samsung chip into the toner cartridge---the "install transfer belt" message is gone and the printer works but has a "low toner" message----i guess i learned my lesson the hard way---anyone in the market for a new transfer belt???........wj
Posted on Sep 19, 2008
Dave you rock! after being frustrated by Samsung's tech support chat for hours and many months leaving the printer alone due to this install transfer belt error, i followed your advise and viola! worked. Now I am stuck with a new belt that I did not need. However, I will still leave the new belt in there as i have had this printer since 2006 and its been working great for me until the error message.
Thanks for sharing your solution.
Posted on May 11, 2012
Cartridge chips were not subject, the setting and it was
Thanks Mr. Bons
Posted on Jul 17, 2012
  • diegoguerrer
    diegoguerrer Jul 17, 2012
    Thanks Mr. Bons
After suffering thru this problem for 2yrs, i think I just found the answer.
I just refilled all my colors (red/blue/yellow), and immediately got the "install transfer belt" error.
1 the manual says that a transfer belt is bad only if it says "Replace Transfer Belt" (if it says "Install Transfer Belt" it thinks the belt is NOT installed!)
2. I painstakingly went thru every inch of changes I had made to the printer since last running it.
I had replaced toner and sensors in the 3 colors, and ahd removed/reinstalled the transfer belt.
At every step I checked the unit (closed door and tried again). This took a long time.
I found that ONE of the counter PCB's (the tiny PCB that you get with a refill kit) was in slightly crooked in its mount. I straightened this and pushed it up to the top of it's slot. THAT fixed it!!
So my guess is this - if your chip isn't perfectly aligned in the sensor slot for it, the unit gets a false read on it, and won't allow you to go forward.
I'm a bit baffled as to why it would show the Transfer Belt error, but that did it for me!
HOpe this helps!!
Posted on Nov 17, 2011
  • Stephen Walburn Nov 18, 2011
    Wow! great reply Dave. I've been struggling with Install Transfer Belt for a couple of hours, just pushed the chip up in the new magenta cartridge I put in and it works!
  • Jim Schwendinger Dec 03, 2011
    Dave, you rock ! I was tearing my hair out and in desperation, checked the chip contacts on the new black toner cartridge I just installed - lo and behold, it was slipping up and not making contact ! I carefully bent the plastic housing a tiny bit to keep the sensor contacts in place, popped it back in, closed the covers and tada ! It works !
    Thank you so much !
  • 507 Answers
You may try this manual online
Posted on Oct 20, 2008
We have this printer at work and the message "INSTALL TRANSFER BELT" appears every time we change a cartridge. I have since found out that it is because the sensor is not aware that the side is shut. You have to push the handle in (the one used to open the side with the cartridges) as far as it will go to alert the sensor that the side has been shut and the transfer belt is installed and in place.
Posted on Sep 18, 2008
  • 141 Answers
Normally the transfer belt is good for an approximation of 50000 copy before need replacement .....Maybe the transfer belt is misplaced check if it's correctly place...
Posted on Mar 31, 2008
Terrible copies down the sides !
759a6310-c94d-4cc9-8251-468d69129a1d.jpgIF IT LOOKS LIKE THIS, LONG STORY SHORT REPLACE BLACK IU
Jul 09, 2013 | Konica Minolta Magicolor 4695MF All-In-One...
Samsung transfer belt color
First Take out the transfer belt out again and refix and put the connectors properly.
Next check the driver settings.
Check the toners are present and working by installing a samsung smart panel software.
then u print .
If the same thing exists. take assistance of service center. it may be HVPS problem.
Mar 25, 2012 | Samsung CLX-3175FW Multifunction Laser...
We have a CLP-300 Series A laser printer which we really like. The problem we are having has recently surfaced after we changed the BLACK toner cartridge. There are skips and light area in the printing...
I think you should contact the manufacturer or vendor who sold you the cartridge. The standard warranty is 90 days. I believe that it will prove to be a bad toner/ drum (which are the same thing for this printer.)
Besides that you can do a "half-test". Stop the print job half way by opening a cover during the print process, before it is transfer to the paper and fused. Look at the drum or transfer belt and see whether the defect exists early in the print process.
There may also be a contact problem with the black toner. Check for bent metal on the toner, or chassis that should mate and conduct charge to the toner.
Item, Inc.
Dec 13, 2010 | Samsung CLP 300 Laser Printer
Please describe how to clean dirty edges on the paper from my KM2430DL printer.
Inside these machines is a rather large, black sheet that is known as the transfer belt. This belt acts to transfer the toner from the drum to the paper, Though if the outside edges of these sheet become worn or mucked up with excess toner, it will produce a copy with vertical bands of toner. In order to attempt to clean this belt, you must first shut the machine off, then open the from cover and locate the transfer belt (may need to remove the toner in order to make it visible,) then, with a damp cloth (water) gently wipe it along with the grain of the belt. Repeat this step until no residual toner appears on the transfer belt, then reconnect everything and print several test pages. If the problem does not reappear, then you are all set. However, if the dirty edges begin to come back, you will need to replace the transfer belt as the wear marks on it are trapping toner and not allowing it to be cleaned properly.
Please keep me informed on your progress and I will help the best I can.
David R.
Dec 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
I've had the same problem with color problems, especially with cyan (blue). I have found that many of the toner cartridges I receive are defective. When I receive a new one, I try it out for a few pages. If the color isn't perfect I return the cartridge and get a replacement. After 1-2 tries, I get one that puts down good color. (A really bad solution I know, but it does get the job done.)
Apr 01, 2009 | Samsung CLP-600N Laser Printer
Samsung clp-510n
there are ways to reset the counters on the toner so that you can continue to print.
Oct 28, 2008 | Samsung CLP-510 Laser Printer
CLP-500 is printing only on left side of paper
You'll need to look at
Drum Unit - these can go beyond their rated life
Transfer Belt - these can fail suddenly and dramatically, often quite soon after their rated life is reached.
Also check Transfer Roller (open the duplexer door to see this - grey (black when new) foam roller about 25mm diameter purple plastic tabs on ends (1 may be black). This is critical to good quality prints, as it maintains the contact between paper and Transfer Belt AND electrostatically pulls the toner off the Transfer Belt onto the paper.
Sep 01, 2008 | Samsung CLP-500 Laser Printer
Hey m8
  • Buxie, first off you have voided your warrenty, secondly
  • If marks repeatedly appear on the printed side of the
    page at even intervals:
    • Clean the inside of the printer. See “Cleaning the
    Inside of the Printer” on page 5.7. After cleaning
    the inside of the printer, if you still have the same
    problems, install a new toner cartridge of the
    problem color. See “Replacing Toner Cartridges” on
    page 5.3.
    • Parts of the printer may have toner on them. If the
    defects occur on the back of the page, the problem
    will likely correct itself after a few more pages.
    • The fusing assembly may be damaged. Contact a
    service representative.
  • If horizontally aligned color or black streaks or
    smears appear:
    • A toner cartridge may be installed improperly.
    Remove the toner cartridge and reinsert.
    • A toner cartridge may be defective. Install a new
    toner cartridge.
    • If the problem persists, the printer may require
    repair. Contact a service representative.
  • SXPRESS- It is normal to have to replace it after that because the starter cartridges are rated for 1500 pages but that is at only 5% page coverage and most people print alot higher coverage than that, and the replacements cover 2000 pages again @ 5% page Coverage
May 20, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-600N Laser Printer Logo
2,128 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
