Question about Creative Labs Creative Webcam
Cam doesn t follow me correctly it strobes
2 Suggested Answers
  • 3422 Answers
SOURCE: cam doesn t follow me correctly
Please try reinstalling the camera drivers/software and also the application you use to view your camera first uninstall all the drivers from control panel>add/remove programs and then reinstall the drivers/software again from the disc provided to you.If you use any online chat messengers for video chat like skype or yahoo then reinstall that also.
This should fix the problem.
Thank you for using fixya.
Posted on Mar 25, 2010
Replaced timing belt how do you time it
you need to make sure it is on top dead center on the crank gear, then align the marks on the cam gear
Apr 12, 2014 | Hyundai Excel Cars & Trucks
Timind belt diagram
i would say your looking at a faulty cam shaft sensor..its located on front side of engine. this fixed the same problem i had..there are 2 sensors one being your cam shaft sensor (normal to go out) and the crank shaft sensor..these work inline with computer to determine correct timing.hope this helps
Dec 07, 2011 | 2000 Ford Escort
How do I line up my marks on cam shaft and flywheel to set timing
Hi mate didn't get any info on what bike you are timing but this procedure is simular for most and is specific for WR YZ 250 426 and 450
set piston to TDC (top dead centre) this can be done by spinning the fly around until you can see the (i) mark stamped on the flywheel line up with the marks on the inspection plug hole (engine case) good idea to probe the cylinder through the spark plug hole to confirm the flywheel mark is correct (I have seen several 426) where the TDC mark does not give accurate TDC on piston so worth second guessing this process.
once TDC is set do not allow piston to move from this point on - starting with the exhaust cam with no slack on the cam chain the dot stamped on the cam sprocket should align with the face of head with the cam lobes pointing outward roughly 45 degrees towards the front wheel when this in place
you do the same with intake cam except the cam lobe will face opposite direction outward and the should be a dot aligning to the head
double check before you go further that when you put your finger in the chain tension hole and you tension the cam chain that when all slack is taken from the cam chain that your dots on both cams align with head face and that you still have piston at TDC if all checks out then this is timed set correct so torque all the cam caps back up install chain tensioner and the recheck all fly wheel marks are in correct position and piston is at TDC and the dot on each cam sprocket aligns to the head if it doesn't then re do the process
don't be surprised if this takes a few attempts as it takes the best of us usually at least two attempts to get all marks to align correctly thats why best to check and double check before you bolt it all down then you can adjust just by lifting one cam out and moving one tooth either direction
You have little room to play with and when you start putting chain on the cam sprockets you will find very little extra chain length to play with you may need to wiggle tug and pull both cams together to get them back in each time but go slow and gentle they do go in they just need to be encouraged
I happy to elaborate on any point if you need - good luck
Regards Jamie
May 28, 2011 | Yamaha XT250X Motorcycles
I have a 94 toyota paseo, i've gotten the crankshaft notch on "0" and on the exaust cam, i have the 5E mark set up right, but i'm having a problem knowing how and where should my intake...
This is a single overhead cam engine, correct? Are you wondering about the other toothed pulley next to the crankshaft pulley? If thats the case then that pulley is the oil pump drive pulley and it has no timing marks. It doesn't matter how it is aligned when you put the belt on.
May 26, 2011 | Toyota Paseo Cars & Trucks
Haw do you time the engine up on a wr426 2002 model
There is no real way to change timing on YZ except change the cam itself to YZ450 cam or simular etc If your wanting to find out how to re install the cams you have already and cam chain then it is simple process but sounds complicated when its written
once TDC is set do not allow piston to move from this point on - starting with the exhaust cam with no slack on the cam chain the dot stamped on the cam sprocket should align with the face of head with the cam lobes pointing outward roughly 45 degrees towards the front wheel when this in place you do the same with intake cam except the cam lobe will face opposite direction outward and the should be a dot aligning to the head
double check before you go further that when you put your finger in the chain tension hole and you tension the cam chain that when all slack is taken from the cam chain that your dots on both cams align with head face and that you still have piston at TDC if all checks out then this is timed set correct so torque all the cam caps back up install chain tensioner and the recheck all fly wheel marks are in correct position and piston is at TDC and the dot on each cam sprocket aligns to the head if it doesn't then re do the process don't be surprised if this takes a few attempts as it takes the best of us usually at least two attempts to get all marks to align correctly thats why best to check and double check before you bolt it all down then you can adjust just by lifting one cam out and moving one tooth either direction
May 24, 2011 | Yamaha WR 426 F Motorcycles
Install my cam
Plug in the Cam and then put the install disc in the CD Drive. After that follow the instructions.
May 03, 2011 | Computers & Internet
Have webcam in my PC, doesn' t know how to use it, please help
Under programs, there is a dell web cam program,there is also a dell web cam help file,if you install skype (a free web cam communication program) it will automatically turn on and off the web cam as the program starts and exits.there are also other dell web cam programs that will let you adjust ,and take snap shots called web cam console and dell webcam manager
Jan 16, 2011 | Dell Inspiron 1525 Notebook
Mar 25, 2010 | Creative Labs Creative Webcam
1999 chrysler 2.4 litre no compresion cam and crank are turning seems to be out of time
The only way to make sure that the timing is correct is with the use of a timing gun. The strobe light that is used on the belt to see the timing. And you may check the timing line if it is aligned.
Sep 27, 2009 | 1999 Chrysler Sebring
I got a new msn
press the flying windows button on the lower left corner of the screen and press computer. It should appear under the drives if it was installed correctly.
Dec 18, 2008 | Acer Aspire 3610 Notebook
Creative Labs Creative Webcam Logo
13 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
