Question about Yamaha 2500 Watt Industrial Inverter Generator YG2800i
How does the generator come away from the engine? regards dan
  • Yamaha Master
  • 5,603 Answers
Most of these one removes the field and then a bolt is inserted in the end of the shaft and a slide hammer is used to pull the rotor loose. There is usually a Woodruff key to the engine shaft.
Posted on May 17, 2010
What is the general specification of Genset 20kv?
Generally 20 Kva power generator can produce more power. The voltage used in this 20 kva generator is 3 phase with frequency 50 Hz. 20 kva generator engine is already very enough for use on buildings that require large electrical power or public places such as shops. According to me HARGEN provides the best high quality genset.
To fill the fuel tank to the full required 62 liters of fuel in order to use this 20 kva generator engine with more leverage.
20 kva generator engine is also issued a noise that can reach 61.7 db or can be heard up to a distance of 7 meters away from where this generator is located.
Sep 11, 2017 | Cars & Trucks
2000 watts generator has no fire
Need advice from a Generator Engineer? Contact us, we are always happy to help!
http://www.generatorguru.com/ask-the-guru/
Regards
The Generator Guru Team
Oct 14, 2016 | Electrical Supplies
94 toyto pickup 4cyl. no signal to inj.
Hi Dan, I believe that on that model of vehicle a distributor was used. The signal for the injection is generated inside the distributor by a second rotor and pick up coil below that for the spark. Check the cables carefully and then the pickup coils. If all else fails, try a replacement ECU. Good used units should be available at a reasonable cost. Regards John
Sep 16, 2012 | Cars & Trucks
After a 2 hour ride out yesterday in daylight,i always turn my lights on to be seen when returned home switched engine off opened garage went to start bike again and completely dead has a data tool duo...
Might have 12.67 volts, but not enough amps to crank engine or light the lights properly. Try putting a charger on the battery, bring it to a full charge. Next, put a load tester on the battery to see if battery is weak or dead cell. If battery checks good, check the charging system. With engine running at idle, put volt meter on battery-read volts, then rev engine to high idle. Volts should climb higher than idle reading.
Apr 18, 2011 | Yamaha YZF Thunder ace 1000 R Motorcycles
Engine ticks over fast periodally when stationary
Hi mark
It sounds like an air fault check your pipes and air mass sensor, may just need a clean up.
Also make sure there is no rips in the pipes as this would cause that also.
Regards
Dan
Feb 04, 2010 | 1985 Volkswagen Golf
Engine runs away
there is a plastic vane that moves in response to the air flow created by the flywheel fan ... the faster the motor runs the more air and the more the vane is deflected .. the vane is connected to the throttle thru a spring .. as the vane is deflected it reduces the throttle setting to maintain a set speed (which is adjustable by a screw) ... if that vane becomes stuck by a leaf or twig then you lose that speed control .. also if it becomes disconnected from the throttle the engine will run away .. the manual on your generator will call that a "govener "
Dec 23, 2009 | Coleman Powermate Premium Plus 6250W...
Generator doesn't start
Hi
Check the spark at the plug,compression and carburation.Priming the engine,putb some gas in the cilinder and start the engine.If the engine runs only the gas you puted in the cilinder you have a delivery problem to find and fix.Remove the carb,disassembly and clean it,check and clean the air and gas filters.
best regards savumihai71
Jan 11, 2009 | Briggs & Stratton Power Products 5,550...
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Yamaha 2500 Watt Industrial Inverter Generator YG2800i Logo
104 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
