Question about Blueant V1 Bluetooth Headset
I have a new blackberry 9630 and a blue ant headset that i have previously paired to another blackberry. i cannot get my bb to find the headset when i search for devices.
  • 214 Answers
I would delete all existing pairing profiles from your blackberry, once that is done do a hard reset by removing the battery from your phone while it is powered on. When it boots back up, reset the V1 by pressing the vol -/+ and MFB all at the exact same time. Ensure the buttons are NOT held simply clicked all at once like a mouse to a computer. When you get a consistent rapid flash the device has been reset and will go automatically into pair mode. Then re-search in your bluetooth menu, select the V1 when it shows up and enter the pin code 0000 if prompted.
Rylan
Posted on Dec 16, 2010
Can i upgrade my blackberry 9630 bluetooth to V2.1?
Jake - the 9630 is a BT version 2.0 device, which is backwards compatible to previous versions. Upgrading to a different version is not possible, as there are different hardware requirements for each. This is the same way that the USB standards are - you can not simply "flash" (install new firmware) a USB 2.0 device to allow it to work like it were a USB 3.0 device.
You can read about the differences between BT versions on Wikipedia.
Nov 22, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Tip
How to pair a Plantronics Explorer 245 Bluetooth headset and a BlackBerry Tour
The Plantronics Explorer 245 headset can be paired with most Bluetooth-capable phones and smartphones to enable hands-free phone conversations. To pair the headset with a BlackBerry Tour, follow the steps below:
Make sure the Plantronics headset is off before trying to pair the two devices. On your BlackBerry, scroll down to Manage Connections (the antenna icon) in your Home folder and click the trackball. From the list of connections, select Set Up Bluetooth. The Add Device box will appear, asking if you want to search or listen for a Bluetooth device.
At this point, turn your Explorer 245 on by sliding the on/off switch toward the microphone end of the earpiece. Once the device powers on (if you have it in your ear, you'll hear a few short tones) you should see repeating red and blue flashes from the LED lights on the side of the headset. If you only see blue flashes, hold down the call button (the side button) for a few seconds, until the lights start flashing red then blue.
Now, on your Tour, select Search. Bluetooth will be enabled if it's not already, and then the BlackBerry will search for nearby devices. When the headset appears on the list of devices found (it should read "245Plantronics" or something similar) select it. A box will appear letting you know that pairing is now complete, and asking if you want to connect to the headset. Select Yes.
Your BlackBerry Tour and Explorer 245 are now paired. If at any point you turn the headset off, turn the BlackBerry off, or turn the BlackBerry's Bluetooth feature off, the two devices will automatically reconnect when they are able. When you look at your list of paired devices on the BlackBerry, the Explorer headset will appear in bold to show that it is currently connected.
on Oct 26, 2010 | RIM BlackBerry? Tour 9630 Smartphone
CAN'T GET MY BLACKBERRY 8330 TO PAIR WITH MY
Did you do the steps listed here?
This is the Plantronics information.
Your new headset includes Plantronics QuickPair technology to simplify
the Bluetooth setup process. The rst time you turn your headset on, your
headset automatically enters pairing mode for 10 minutes. Once paired
successfully, your headset stays on for instant use.
If not sucessfully paired after 10 minutes, your headset automatically
powers o. When you turn the headset on again, it automatically goes
into pairing mode until successfully paired with a Bluetooth phone.
To pair your headset for the rst time:
Turn ON the Bluetooth feature on your phone.
TIP: For most phones, select Settings/Tools > Connections > Bluetooth > On.
See your phone’s user guide for more information.
Press and hold the call control button to turn on your headset. (The indicator
ashes red/blue to show that the headset is on and in pairing mode.)
TIP: If you don’t see the red/blue ash, press and hold the call control button to
turn your headset o, and then press and hold the call control button again until
you see the red/blue ash.
Use the commands on your phone to locate your headset.
Search > 520Plantronics. See your phone’s user guide for more information.
When prompted for the passkey, enter 0000.
When pairing is successful, the indicator on your headset ashes blue. Your
headset is now connected and ready to use.
Apr 15, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I have a new blackberry 9630 and a blue ant headset that i have previously paired to another blackberry. i cannot get my BB to find the headset when i search for devices.
You need to put it into discovery mode before you tell your phone to look for it. You probably hold down the main button until it stays solid lit to do that.
Mar 25, 2010 | Blueant V1 Bluetooth Headset
Can't get new Blackberry 9630 to discover Plantronics 330. I've followed the pairing instructions for both instruments, but the Blackberry doesn't detect the headset no matter how close it is.
Once you make your BlackBerry discoverable, then put the Plantronics Explorer 330 into pairing mode by holding the call control button until the headset flashes red and blue. Here is the link below for the Explorer 320 user guide which has the pairing instructions, it will be the same for the 330.
Plantronics Explorer 320 User's Guide
Good luck from Headsets Direct!
Feb 02, 2010 | Plantronics Explorer 330 Headset
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
Problem Pairing Blackberry 8700 w/ BlueAnt Z9 Bluetooth Headset
This problem has been solved by turning on the blue ant system then holding down the vol - and vol + buttons simultaneously for 5 secs.
Dec 15, 2008 | RIM BlackBerry 8700c Cellular Phone
Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Dec 14, 2008 | Nokia Bluetooth Headset BH-207 Wireless...
Plantronics 520 will not pair
"Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue."
Dec 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
Blueant V1 Bluetooth Headset Logo
104 people viewed this question
Top Blueant Radio Communications Experts
Michael Vincent Cruz
aliasger yq
Paul Chapman
Paul Chapman
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
