KONICA 1015 COPIER - CODE J11, BUT THERE IS NO
Konica 1015 copier - code J11 but there is no paper jamming that I can determine when opened up
SOURCE: Konica 7415 erro code C14A3
I had the same error on Di 1610 and i solved it by just cleaning the mirrors in the scanning unit.
Posted on Mar 25, 2008
  • 82 Answers
SOURCE: Do you know how to
I believe you have a temperator warm up issue, when does the error ocuur after initially turning on, if it's within 120 seconds or less it's probably a fuse if after it's probably a lamp.
\Thank You,
Mikey
Posted on Apr 03, 2008
SOURCE: Does anyone know what the
77-2 is a finisher prob..Make sure nothing is under the finisher like a small trash can preventing the finisher from moving up/down.Turn off then on,if prob. still there remove finisher by pressing a pen/pencil in small hole inside finisher door and pull fin. towards you. This will let you use copier until service rep. gets there.
Posted on Jun 20, 2008
ginko
  • 19396 Answers
SOURCE: xerox XC830 table top copier.
It is a problem with the mechanics, try playing with the traction wheels at the back of the prointer
Posted on Jul 06, 2008
  • 7 Answers
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
Posted on Aug 22, 2009
On Konica 1212 what does J11 mean and F54?
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Dec 05, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
I have Konica Minolta bizhub C353 and the paper keeps getting jammed after several prints. I just cleared code error c-3421 but it keeps getting jammed. Any help.
First Are informing the copier of the proper paper weight
? The paper weight is on the outer wrapping of the paper such as 75 g/m2 or 90 g/m2 etc. did you tell the machine that? Did you select the same weight when you sent the print job over to the machine in your print properties/perferencies ? They have to match! Check the orientation of the paper also ensue they match landscape or portrait? they have to match in the computer also.
Oct 10, 2013 | Konica Minolta Konica Bizhub C353 Drum...
Konica minolta EP-1031 PC code and toner install
PC MEANS NO PAPER IN THE TRAY OR PAPER JAM IN MACHINE WHEN TURNED ON. WHEN OUT OF TONER RED LIGHT SHAPED LIKE A PYRAMID WILL COME ON
Apr 16, 2010 | Office Equipment & Supplies
KONICA 1015 COPIER - CODE J11, BUT THERE IS NO PAPER JAMMING THAT I CAN DETERMINE WHEN OPENED UP
check the sensors, clean it or check the wire connection of the sensors maybe it was eaten by rat.
Mar 25, 2010 | Konica Minolta Office Equipment & Supplies
Error code F34 on Konica 1015 copier is there any way to fix without service call?
No...it's a fuser error (low warm up temperature)...It's a blown fuse, or lamp, and the code can only be reset in 'service mode'after fixing the fault
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Konica 1015 Paper Jam code J12 that does not exist
PS401 actuator is stuck. -------------------------------------------------------------------------------------------------------------------------------------------------
DO THIS FIRST
If this machine was running before ,check the Actuator on the side door .in the center between the 2 small rollers its balck and snaps in..
hope that help you
Nov 07, 2008 | Ricoh 6513 Copier
Konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Aug 01, 2008 | Ricoh 6513 Copier
Konica 4155 - J16 Paper Jam
First, check if the paper loaded is matched with the copier settings.
If that doesn't solve the problem, carefully check the paper path sensors.
Feb 07, 2008 | Office Equipment & Supplies
41 people viewed this question
jasbo
jasbo
