Question about Canon PIXMA MP510 All-In-One InkJet Printer
Ink cartridge problem
Ink cartrdges were replaced with all new Canon cartridges and the prnter will not recognize the No. 2 Cartridge.  The printer is useless and the $50.00 to replace the cartridges was a waste of money.  Please advise..
upgrade to CISS kit ,now ink cartridge is show ink out
  • vohoman May 03, 2008
    hi,
    the tank lights are blinking.i replaced 2 of them with full ones but it doesnt work
    sincerely,
    vohoman
  • Anonymous Jun 08, 2008
    I, too, replaced all ink cartridges and I still get "The following ink tank cannot be recognized."  Canon is sending me more ink cartridges to try, since it is still under warranty, but I  don't think that will work either.  Lousy copier for the money!
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
You may find that doing a clean and alignment assists with this problem.
Posted on Aug 20, 2008
Prnter won't recognize red ink cartridge. When I push down on the cartridge the recognition light comes on, but goes off when I release to close printer cover.
My printer just died. The first indication of a problem was ink cartridges not being recognized. I replaced 3 in one night. The next time I went to print the entire unit just lost power and will no longer power on. From what I've been reading a bad print head can fry the logic board. At that point the only solution is to replace the board. For a 5+ year old machine and a logic board that will cost ~$100, it doesn't seem worth repairing.
Dec 14, 2012 | Canon PIXMA MP830 All-In-One InkJet...
The cartridge
Is this a Canon ink cartridge or a refilled ink cartridge or an after market type. If it is not a Canon ink cartridge then printer will reject the ink cartridge.
Dec 23, 2011 | Canon PIXMA Office Equipment & Supplies
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
New Canon ink tank not recognized.
Check that the cartridge chip is not soiled or damaged in any way... Give it a quick clean, check that there's no ink anywhere else on the cartridge as there are sensor points that an LED uses to check the cartridge ink levels too.
If none of that works, phone Canon and request a replacement as some cartridges are known to have faulty chips.
Jan 29, 2009 | Canon MX700 Office All-In-One InkJet...
Dead printer after replacing Cartridges in Kodak ESP3 AiO Printer
You should never use a COMPATIBLE ink cartridge or a ink cartrdge from different manufacturer......if you do then you are damaging your printer yourself and no one can help you not even kodak tech support.........try using genuine ink cartridge if you look on side of the ink cartridge then you will see a code which will indicate if its genuine or not try and match those codes with the codes that i will mention if it does not match then its not genuine...........
  • 1K3156
  • 1K3157
  • 1K3178
  • 1K3177
  • 1K3189
  • 1K3190
  • 1K3627
  • 1K3622
  • 1K3629
  • 1K3638
  • 1K3620
  • 1K3621
let me know if this was helpful.......
Jan 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Cannot recognize ink cartridge
I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
Jul 22, 2008 | Canon PIXMA MP460 All-In-One InkJet...
I have a new Canon Pixma printer. Every time I replace an ink cartridge, the printer all of a sudden won't recognize the cartridge. After I clean the nozzles and play with it, it recognizes the new...
I spoke with Canon and they said the PIXMA 620 does not accept refilled cartridges. Occasionally they work without a problem but you should buy a new cartridge each time. I spoke with an authorized Canon repair company and the technician said that the thickness of the ink in the refills is thinner and can ruin the printhead so even if it does recognize the cartridge, refilled cartridges will ruin printhead and are a bad idea. Canon needs to become more ecologically and economically viable if you ask me!
Jun 10, 2008 | Office Equipment & Supplies
Solution: Snap in ink tanks properly MP500
Ink Tank Seated Properly Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Ink tank
Users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again,
  • By replace a new ink cartridge will sure help as the partial used one would be faulty already, and if you are using Canon ink cartridge, do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge as it due to the unique feature that Canon has build on the ink cartridges not properly done, which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges.
Mar 05, 2008 | Canon Pixma MP500 All-In-One InkJet...
Dell 942 AIO printer cartridge problem
Was your replacement cartridge a new dell product? If it was, the sensor on the prnter should recognize it as new and reset the indicator to full. If, however, the cartridge was refilled, remanufactured, or otherwise an off brand, the ink indicator will show it to be empty. Just ignore and use the printer as normal -- it will print just fine, but you may need to press the select button to get it to start printing the first page.
Aug 26, 2007 | Dell 942 All-In-One InkJet Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
168 people viewed this question
old marine
old marine
