5101 fault on Mitsubishi Unit compressor changed less than a year ago
2 Suggested Answers
SOURCE: I have a Lennox CH23.51 series coil unit using R22
This evaporator core is R-22 / R-410A compatible. The Thermostatic Expansion Valve (TXV) is for R-22. If retrofitting to R-410A, a new TXV metering device would be required, but the evap. core itself could be re-used (as long as you stick with the same Tonnage you have now). If upgrading to a higher tonnage system (like going from 4-Ton to 5-Ton), then you would need a totally new evaporator core.
Posted on Jul 22, 2011
Rough idle when car is started and makes noise with acceleration
If you run with a check engine light on then you are looking for big dollars for repairs.. The light is there to tell you to have the fault codes read so that repairs can be kept to a minimum. So run the fault codes and find the fault .
Jan 21, 2014 | 2006 Cadillac CTS
Hello. I have this fridge-freezer, but unfortunately I can't remember when it was bought. I guess it must be between 7 and 12 years ago! It's worked fine but a couple of days ago it started making...
By your description you may have a compressor problem. The noise is makes if a buzzing noise when it struggle to start (locked up). The clicking noise would be the relay clicking out on overload to the compressor.
If your correct on the date, you will be better off replacing the unit then looking into the repair, a normal compressor change out can run over 500.00. Your best bet is to cut your losses and replace the unit before spending any more money on it.
Good Luck
Aug 28, 2011 | Refrigerators
The pressure is getting less and less daily , hydrovain 705
Air Compressors do wear out. Rings wear, valves wear.
The compressor I use at work would build 135 PSI in about 8 - 10 minutes a year ago. Today, I quit at 85 PSI after more than 30 minutes running time. told the boss - Get a new one!
Dec 18, 2009 | Air Tools & Compressors
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Error code E39 for Mitsubishi Heavy Industry Ceiling cassett type
E39 Fault is thermister, Mitsubishi way of saying im not going to start because there is something wrong. Generlly it is compressor fault or short of gas. Im guessing if you turned the power out. Waited twenty seconds, turn it back on. Now if you go to the outdoor part. Wait exactly 3 mins. If you hear the compressor try to start and fail then it would more then likely be your compressor if you dont hear anything and the unit faults out it will either be a board or short of gas.
Either way If the unit is under five years old get a warrenty agent out to look at it.
Sorry I couldnt tell you for sure but MHI are very vague when it comes to fault codes
Mar 03, 2009 | Mitsubishi Heating & Cooling
Recall
I had the 5101 I just sent it back last week to manufacturer,most of oil filled heaters make a noise as the oil heats up. The 5101 had a black control panel &black wheels & foot rest. Hope i was of some help. If u have more ? let me know. slinger5@localnet.com
Jan 26, 2008 | Lakewood 2727 Heater
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
