Question about Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 all-in-one printer
I got everything set up. The printer will print pictures directly from my camera and will print photos from my computer but, I can't transfer them from my camera to my computer. The printer just beeps when I hit the tranfer button on the printer. Any suggestions greatly appreciated.
  • gidio Apr 01, 2008
    Thanks for the #. Ends up the program didn't load correctly and I downloaded it directly from the site.
If u plug it in and beeps 3 time when plugged in means that it isn't compatable with the printer if doesn't beep 3 times call 1-800-235-6325 cameras option 12 onezoom 13
Posted on Mar 31, 2008
SOURCE:
Prints only pictures and not text
Run the printer maintenance program and clean the printhead. If that doesn't fix the problem, contact Kodak support. If needed, they will exchange the printhead for a new one.
Feb 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I can print 4x6 photos but not documents from my computer
Maybe your phototray is still engaged. If the green light by the photo tray is on - then it is engaged and you cannot print documents. Lift up the clear lid of the little photo tray, pull it back towards you until it clicks in place. The light will go off. Close the tray lid.
You should be able to print documents now. Make sure the document tray below the photo tray has paper in it.
If all else fails, try Kodak's Help on-line at this site www.kodak.com/go/5100aiosupport
They have an on-line survey tool to help you with your problem. Good luck.
Dec 02, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300aio printing borderless photos problem
call kodak, they have good support and you'll speak to a human quickly
Oct 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Color is all wrong
Your pictures are coming out with a blue tint. Remove the color catridge and look at the bottom of it. the Yellow is probably green. If it isn't, trying performing a printhead cleaning through your home center. After that, calibrate the printer, you may see that on the calibration sheet, that colors are missing. Scan the calibration page and then try your printing your pictures. If that doesn't work, contact kodak tech support, you need a new printhead.
Sep 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printer will not read SD card from Panasonic Lumix DMC TZ3
Put the card in an adapter or in your computer. Make sure the pictures are not in folders. The printer is unable to read them if they are.
Also, the file size of the picture cannot be over 8 MB and the image size has to be below 12 megapixels.
Jul 16, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Easyshare 5100 not printing on correct side of paper
Load a single 8x10 page and press Copy + Cancel until the printer feeds the paper. It will spit it out blank. Try printing another photo. Make sure Kodak logo faces up when you load it
Jul 12, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today.  For over 1 year it has worked just fine.  Any ideas?
Apr 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Flashing red check ink lights
printer had an error that couldnt be fixed so had to replace it.
Apr 06, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Photo paper
1. Never put XtraLife paper from a printer dock in any inkjet printer. This paper is not made for inkjets. The ink will simply spill all over the place.
2. You can use any paper you wish that is inkjet paper but you must set the appropriate settings through the print manager if the paper is anything but Kodak inkjet photo paper. The 5100, 5300, and 5500 all recognize the backprint on the Kodak paper and automatically optimize the settings. Other brands of paper are not optimized in this fashion and therefore must be done manually through the print manager or software.
Mar 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Photo copy problem
You need to connect a photo source to the printer to select "photo" mode. A usb drive or a pictbridge camera would be suitable candidates.
Dec 25, 2007 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
