Question about Yamaha YST-MS25 Computer Speakers
Yamaha yst-ms25 -faulty connection on cable into woofer
Connection at woofer intermittent operation - need connector type and pin connections if possible
4 Suggested Answers
  • 3 Answers
SOURCE: Yamaha YST-MS50 speakers to my i Mac.
You can connect the Yamaha YST MS50 speakers to any audio source that relies on a 3.5mm jack. The YST MS50 should have two audio inputs, so you can use one of them to connect the speakers to your computer. If you don't have a 3.5mm male to male cable, then you can buy that at any electronics store or online.
Posted on May 14, 2009
adampune
  • 125 Answers
SOURCE: i need a manual for my Yamaha YST-MS25 Computer
Yamaha YST-M15 computer Speakers Information
open this LINK:
http://www.retrevo.com/s/Yamaha-YST-MS55D-Speakers-review-manual/id/320ci368/t/1-2/
there some manual /information about this product
Posted on Jan 28, 2010
andcal
  • 182 Answers
SOURCE: Where xan i purchase parts
I am not sure exactly what part you are talking about, but if y ou are talking about something that looks like this: http://www.geocities.co.jp/SiliconValley-PaloAlto/6402/yst-ms25c.jpg (the one on the left, not the one on the right)
Then, you might want to try Fry's Electronics or Radio Shack.
Posted on May 08, 2011
I obtained a pair of Yamaha YST MS50 speakers with no subwoofer. Can they be adapted to use a different sub, such as the inexpensive Yamaha YST MSW5? The clear problem is in different cabling.
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 03, 2016 | Yamaha YST-MS50 Computer Speakers
Anyone know where to get an 8 pin din cable for my Yamaha YST-MS55D multimedia speakers?
I just bought one here in Holland in the handyman store. Where do you live?
Oct 07, 2014 | Yamaha YST-MS55D Computer Speakers
1992 virago 535 backfiring
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://viragohelp.com/virago-owners-clubvoc-archives/deceleration-backfiring
Engine popping Not sure where to start
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2005/LIT-11626-18-21_1000.pdf
Mar 09, 2012 | 1988 Yamaha XV 535 Virago DX
Where xan i purchase parts like the din internal connectors that mount on the motherboard of the yst-ms25
May 08, 2011 | Yamaha YST-MS25 Computer Speakers
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
I cannot connect the 8 pin plug anymore
please take a look at the pins ...are they bent?
Dec 02, 2010 | Yamaha YST-MS25 Computer Speakers
How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Dec 16, 2008 | Yamaha YST-MSW10 Computer Speakers
Yamaha NX-SW300 sub woofer
Yes, that type of connector is often used for a VGA signal for a computer monitor. But in this case it is an all-in-one connector Yamaha used in order to simplify the hookup of this home theatre system. Unfortunately, the subwoofer is only usable with the DVR-S300 receiver/DVD player.
Apr 03, 2008 | Yamaha YST-SW160 Subwoofer
110 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
