Question about Acer Aspire™ T180 PC Desktop
My flash drives and other decices can't be
My flash drives and other devices can't be accessed by the usb
  • 570 Answers
There might be a problem with your usb port try another devices if they are detected than the problem may be with your device
thanks
Posted on May 16, 2010
Flash drive
CHECK IN DEVICE MANAGER HARD DRIVES
IF IT DETECT
GO TO DISK MANAGEMENT AND RIGHTCLICK ON DRIVE BOX FORMAT IT
Nov 11, 2013 | Kingston DataTraveler 100 G2 - USB Flash...
Pen drive access denied
USB ports and devices make connecting to another computing device convenient.
USB technology has been around since 1996, and is a feature found on most modern computing devices.
If your device is denied access to one of its USB features, do some troubleshooting to isolate and resolve the problem.
Viruses
Some computers come with a security feature that automatically denies access to a USB device, such as a flash drive, if harmful content is detected.
Installing an anti-virus software application and regularly scanning the computer and any connected USB devices can help you avoid experiencing denied access to a USB device.
Avoid opening USB flash drive files that you cannot identify or do not recognize, as these types of files are how viruses find their way onto unprotected computers.
Incompatibility
Inserting an incompatible device into your computer's USB port can also cause you to be denied access to your device's USB features.
For instance, if your computer supports USB 1.0 technology and you insert a USB 2.0 or USB 3.0 connector, the computer can experience interfacing problems that may cause a "USB access denied" prompt or situation.
If other USB devices begin to malfunction after inserting an incompatible USB cable into your computer, turning the computer off and back on again may resolve the situation.
Formatting
USB flash drives, also known as pen or thumb drives, are among the most common types of USB devices used in conjunction with computers.
Most USB flash drives are formatted using one of three types of formatting methods: FAT16, FAT32 or NTFS.
If you've formatted a USB flash drive using one method, used it on the computer and then reformatted the drive using another method, you can be denied access to the flash drive through the computer's USB port.
Wiping the flash drive clean and reformatting it again can resolve this type of problem.
Considerations
Many computer accessories, including printers and pointing devices, connect through the machine's USB ports and can interface interchangeably with multiple computing devices.
This feature increases the risks of picking up viruses and experiencing unauthorized reformatting. Limiting the amount of computers your USB devices accesses can help you avoid these situations.
Damaged USB cables can also make it impossible to access USB devices when they are connected to your computer.
USB cable damage usually occurs at the points where the cable and its connectors meet. Replace any damaged USB cables.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
http://www.webopedia.com/TERM/U/USB.html
Sep 06, 2013 | Computers & Internet
USB not recognized
Click start then run and type decice manager. Once that opens look for usb devices and right click then update driver. Alternatively type your computer make and model into google followed by usb drivers and download that way. Hope this helps.
Oct 20, 2012 | Medion MD-1768 PC Desktop
I can't access my western digital external hard drive to any computers..How can i do?
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Jun 13, 2011 | Western Digital Passport 320GB External...
Try updating the usb drivers in the device manager, right click on my computer and hit properties to get there. Find the usb host controllers in the drop down tree, right click on them and choose update driver and use the internet option to download any updates that you might require. hopefuly this will solve your usb problem.
Mar 25, 2010 | Acer Aspire™ T180 PC Desktop
No access to USB drive when inserted (Windows). ''Malfunction'' error message.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 30, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
DRIVER FOR EASYDISK USB FLASH DRIVE WHICH WORKS ON WINDOWS 98 BUT I WANT THE SAME TO BE ACCESSED BY WINDOWS XP TO HELP ME ACCESS DATA STORED THEREIN. THIS IS A 16 MB FLASH DRIVE MANUFACTURED BY SHENZEN...
you do not need a driver for windows xp - the flash drive should be recognized automatically.
the driver and utilities can be found here http://www.easydiskusa.com/eddrivers.php
Mar 22, 2009 | Lexar JumpDrive Classic Portable USB Data...
My computer wont detect my USB flash drive
i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
Thanking you
M. Sridhar
Nov 24, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
Acer Aspire™ T180 PC Desktop Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
