I have a beko eco care wma1613s washing machine. It does its full cycle but after the wash cycle it doesnt drain the water. Can you help?
Sounds like the drain pump blocked or something is stuck in it stopping it from working, i took mine out, cleaned it and it works fine now
Posted on Aug 13, 2010
Have Beko WME7247W Washing Machine problem. On full wash the mc loads water then stops. Timer does not progress. Water does not heat. Drum does not turn. On Spin and Drain cycle pump works but spin does...
I had a similar sort of problem, and finally called a Beko engineer out. The machine was pushed too far back and had either blocked the water pipe, or waste pipe.... can't remember which, but simply pulling the machine out by an inch cured the problem!
Mar 09, 2014 | Beko WME7247W Washing Machine
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
BEKO eco care WMA W10, replaced brushes still wont wash or spin,pls help
Hi if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 08, 2013 | Beko Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Beko washing machine not draining
If the drain hose is stretched too much to reach the standpipe, the hose can pitch.
May 21, 2012 | Beko WM5140W
When it is on Eco wash the sudsy water drains out and does not return to the bowl so we have to use traditional wash ... it is a new machine ... I set the drain hose up as per operators manual i.e. maximum...
ECO wash cycles are never that successful, they are very picky and sometimes something as simple as the water hardness messes the cycles up, Also sometimes the cycles don't function quite as advertised.
The head height of the drain will also affect the ability for the operation of the ECO Cycle.
Mar 10, 2012 | Washing Machines
Washing machine won't rinse, drain or spin
COULD BE THE PUMP MOTOR GONE BUT FIRST CHECK THE FLUF FILTER IF FITTED
Dec 30, 2009 | Washing Machines
Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Nov 19, 2009 | Washing Machines
Instruction manual for a beko 1512s eco care washing machine
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Apr 01, 2009 | Washing Machines
Washing Machines Logo
406 people viewed this question
Top Washing Machines Experts
