Question about Texas Instruments TI-83 Plus Calculator
How to put letters in calculator from an equation. Ex: 5x + 2y=
  • Texas Instru... Master
  • 7,993 Answers
Use the âLPHA key followed by the letter you want. The letter is written on the body of calculator in the same color as that of the ALPHA key (Green).
Posted on May 16, 2010
Determine the x and y intercept of the graph for each equation. 5x-y=-5 And -3x+2y=7
5x-y=-5 answer x=-1, y= 5 http://www.wolframalpha.com/input/?i=Determine+the+x+and+y+intercept+of+the+graph+for+equation%3A+5x-y%3D-5
-3x+2y=7 answer x = -7/3, y = 7/2 http://www.wolframalpha.com/input/?i=Determine+the+x+and+y+intercept+of+the+graph+for+equation%3A+-3x%2B2y%3D7
Feb 23, 2015 | Office Equipment & Supplies
Do i use the elimination or substitution method for the equations 16x-2y=16 and 4x=2y-8
Both should work.
16x - 2y = 16
4x - 2y = -8
12x = 24
x = 2
y = 8
2y=4x + 8
y = 2x + 4
16x - 2(2x + 4) = 16
16x - 4x -8 = 16
12x = 24
x = 2
y = 8
Good luck.
Paul
Oct 05, 2014 | Office Equipment & Supplies
What ia the sulution of 3y-6x=-3
To find the solution, first find the value of y for each equation.
Then substitue one equation into the other so that you only the x variable left.
Then just solve for x.
Once you have a value for x, then you can easily solve for y.
So for the first equation:
3y - 6x = -3
3y = 6x - 3
y = 2x - 1
Now for the second equation:
2y + 8x = 10
2y = -8x + 10
y = -4x + 5
Since both equations equal y, they also equal each other, therefore:
2x - 1 = -4x + 5
Now just solve for x:
2x + 4x = 5 + 1
6x = 6
x=1
Now substitute x=1 into either original equation:
y = 2x - 1
y = 2 (1) - 1
y = 2 - 1
y = 1
Therefore the solution is x=1 and y=1
Good luck, I hope that helps.
Joe.
Nov 09, 2011 | Texas Instruments TI-84 Plus Silver...
How do I solve for y, 2y + (y-3)=18 - 2 (y+3). with the casio fx-300es? and if I cant whats the calculator that will. thanx
Do you really need a calculator to solve a linear equation?
Let us see how to solve it without a calculator.
Remove the parentheses fronm the second term on the left : y-3
Use the distributive property on the last term on the right side -2y-6
Take the term -3 to the right side, changing its sign in the process (becomes +3)
Take the -2y term to the left making it +2y.
3y +2y=18+3-6 or 5y=15 and the answer is straightforward .
As to your Casio FX300ES, it cannot solve equations because it does not have an EQUATION calculation mode. The Casios FX-115ES and FX-991ES have an Equation Mode. If you use any of the two to solve an equation in one variable (linear, quadratic or other) the unknown is taken to be x by default. You would have to change the name of the variable from y to x.
Sep 08, 2011 | Casio fx-300ES Calculator
Michael buys two bags of chips and three boxes of pretzels for 413. He then buys another bag of chips and two boxes of pretzels for 239. Find the cost of each bag of chips and each box of pretzels.
Price of bag of chips s X and price of box of pretzels is Y.
Now you can write following equations:
2X+3Y=413
X+2Y=239
From second equation you know that X is 239-2Y, and you put that in first equation:
2*(239-2Y)+3Y=413
or
-4Y+3Y=413-2*239
Finally we have for Y: Y=65 and X=239-2Y=109.
Aug 13, 2011 | Office Equipment & Supplies
How to find the polynomial roots in TI-83 Plus
One way is to use the Polynomial Root Finder and Simultaneous Equation Solver app.
Press the APPS key, then select PlySmlt2 and press ENTER. Press ENTER to get past the opening screen, then select "POLY ROOT FINDER" and press ENTER. Select the order of the polynomial and other settings as desired. Press F5 (the GRAPH key) to go to the next screen. Enter the polynomial coefficients, then press F5 to solve. The next screen will show you the roots (unless you selected real roots and the polynomial doesn't have any real roots).
If you don't have the app installed, you can download it from
http://education.ti.com/educationportal/sites/US/productDetail/us_poly_83_84.html
Jan 20, 2011 | Texas Instruments TI-83 Plus Calculator
I am trying to solve a quadratic function using the calculator but i dont seem to be able to do so. For example if i had a question like 5x^2 + 15x +3, how would i use the sharp el-w535 to find the x...
This expression 5x^2+15x+3 is not an equation, therefore it can have any value depending on the value of x. You have to make it an equation before looking for the particular value of x that satisfy your equation 5x^2+15x+3 =0
This calculator cannot solve equations because it does not have an equation solver.
Dec 15, 2010 | Sharp ELW535 Calculator
Solving a linear equation from TI30XS Multiview
Sorry this calculator cannot solve equations. It does not have the program. It does not know how to do those things. However it can calculate. Before you can use the calculator you must prepare all yourself. When you have solved the problem, you ask the calculator to compute the value of what you found.
Let us clean the equation a bit
2(x-4) -5x=-5
Get rid of the parentheses 2(x-4) becomes 2x-2*4=2x-8 .Put that result where it was in equation
2x-8 -5x=-5
Group together the terms that have x in them 2x-5x=-3x
Then
2x-8-5x=-5, becomes -3x-8=-5
You want to isolate the term with x (have it on one side, and the others on the other side) -3x= -5 -(-8)= -5+8 =3.
The equation becomes
-3x=3 Thus -x=3/3=1 and x=-1.
In general you would have obtained x= (some number/some other number) and that is where the calculator would intervene.
Hope it helps.
Sep 11, 2009 | Texas Instruments TI-30XA Calculator
Solving systems of equations by elimination
Hi joanmae jmeh;
You can add these equations just like you would numbers
3x + 2y = 7
5x - 2y = 1
8x =8
x=1
Now plug x = 1 back into either equation and you can solve for y
Y = 2
When you add the 2 equations together the +2y and the -2y cancel
out
Hope this helps Loringh Please leave a rating for me Thks
Dec 01, 2008 | Bagatrix Algebra Solved! 2005 (105101) for...
Texas Instruments TI-83 Plus Calculator Logo
117 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
