Question about Emerson Quiet Kool 12GJ14 Air Conditioner
Problem just put it in the wall and their are alot openings on the top and ice must of formed in it and will not start..if it drys will it start..and what can I do to keep out water ..has openings all over it and water from the roof hits it..carl
Will it start once it dries out .it does not make a peep when you turn it on when its wet, is there a reset switch in them or is the motor shorted out..carl
Posted on Apr 01, 2008
  • 236 Answers
Seal all openings on the wall with foam to avoid Icing form. Install the unit in correct position to avoid water entering in the room.
Posted on Mar 31, 2008
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Lsc27914st/00 ice maker will not fill the tray, prior to that is the water leaked down the walls of the freezer
My name is Peter. I am a retired field service refrigeration technician.
There is a white plastic fill tube that runs from the back of your refrigerator into your freezer. This fill tube in the freezer section is open at the top. This tube goes into the ice maker fill cup on the right hand side of your ice maker. Opening and closing the freezer door - warm air gets in, forms condensate, and freezes. So, your fill tube and/or your fill tube is blocked with ice.
Remove the extra storage shelf in front of the ice maker. Using a hair dryer defrost the ice in the fill cup and fill tube. This is located on the right hand side of you icemaker.
Oct 27, 2014 | Refrigerators
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Our kennmore side by side referigerator bought two years ago seems to have lot of ice in the freezer compartment. there is ice formed over the vents in the referigerator side and things (milk) is getting...
is the ice on the back wall or was the door left open?also send the model number,you'll find it in the fridge side on the right hand wall up near the ceiling,it will start with like 106. or similar
Sep 04, 2010 | Kenmore Refrigerators
Icemaker water line is frozen...i will remove everything and open the freezer door to let it warm up. When I chill the freezer again do I keep the icemaker arm up until the freezer is cold and then lower...
Dont leave freezer door open it will cause alot of problems. The ice maker will not call for water until the temp in freezer is cold enough. Remove the ice jam. If you remove from back of freezer it helps alot. Pull out of the back wall and remove ice be sure to put it back the way it was. Any further assistance please feel free to contact me.
Jun 16, 2010 | KitchenAid KSBS25FK Side by Side...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
May 07, 2009 | Refrigerators
Ice forming on freezer back wall of 6 year old top
u have a defrost problem unplug for 4 or 5 hrs with door open will work like new till u can get a tech out to replace parts
Mar 17, 2009 | Kenmore 18.9 cu. ft. Top Mount...
Wet wall
its possibly a normal occurrence when you open the door of the fridge or freezer hot humid air is drawn in by the fan and condenses with the cold air to form water droplets which most of the time are dealt with when the unit defrosts check to make sure all the doors are sealing properly and tilt the fridge back just a little to make sure it has a tight seal as to the fan that's a judgment call on your part rule we used to use when i was in the Field is if it bugs the customer its too loud
Feb 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Emerson Quiet Kool 12GJ14 Air Conditioner Logo
Top Emerson Heating & Cooling Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
