Question about Microsoft Windows XP Home Edition
Dns failure comes up every time i try to enter my hotmail messages
  • 35 Answers
You can also try to reinstall the Network adapter
Click Start -> Right click on My computer -> Properties -> hardware -> device manager -> Network adapters
Right click and uninstall provided you have the driver disk from the manufacturer. After you uninstalled click Action on the device manager and click scan for hardware changes. This should automatically install the driver for the network adapter. Otherwise install the driver from the manufacturer disk
Good luck
Bala
Posted on Jun 25, 2008
  • Microsoft Master
  • 13,433 Answers
I supose other websites work?
Download and use this program to clean your pc from unwanted harmfull software
Spybot - Search & Destroy
Protect yourself against spyware 1.5.2
http://www.safer-networking.org/en/index.html
Posted on Mar 31, 2008
  • Ekse Apr 02, 2008
    If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
    Thanks alot!
IMovie won't share videos to Facebook, always says "request timed out" What do I do?!?!
That seems to be a problem with your network, if on wifi try going nearer to your router, if that doesn't work try flushing your dns. You could try using a new network to do it too.
Source: http://docs.cpanel.net/twiki/bin/view/AllDocumentation/ClearingBrowserCache
  1. Click the Start button.
  2. Enter cmd in the Start menu search field.
  3. Right-click on Command Prompt and select Run as Administrator.
  4. Type the following command and press Enter: ipconfig /flushdns
  5. If the command was successful, you will see the following message: Windows IP configuration successfully flushed the DNS Resolver Cache.
Aug 19, 2014 | Apple iMovie
DNS lookup fail at random times
I can suggest you a solution. I am not sure whether it will work or not but you can try this and see if that works.
Open the setup page of Linksys router using 192.168.1.1.
On the setup page you will see Static DNS 1. Enter 4.2.2.2 in Static DNS1. And Enter 4.2.2.3 in static DNS 2 option. Save the settings.
See if this works.
Also make sure that firmware on your router is upgraded.
Jun 05, 2012 | Cisco Linksys Wireless N Home Router...
Netflix is not working
Cannot Connect to Netflix" message
  • Make sure your home Internet connection is compatible (more info)
  • Manually change your Wii console's DNS settings. To do this, follow these steps:
    1. Access the Wii system settings (how to), and use the right arrow twice and select "Internet."
    2. Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using.
    3. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS."
    4. Select "No," and choose "Advanced Settings."
    5. Click into the "Primary DNS" field and enter: 008.008.008.008
    6. Click into the "Secondary DNS" field and enter: 008.008.004.004 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
    7. Select "Confirm," and then "Save."
    8. Select "OK" to start the connection test. Once the test finishes, try to download the update again.
Oct 16, 2011 | Nintendo Wii Console
After going through the wireless connection guide I get an authenication for ssid and excellent connection status, but when I click on the internet explorer logo I get error message "Cannot find...
Check the DNS numbers you have in your network configuration under TCP/IP. Can you ping google? Go to the START button, then RUN and type in CMD and hit enter. A dos prompt window will open (black screen with text and the cursor will be blinking). Type in - ping www.google.com - and hit enter. It should come back with times it takes to ping google. If it comes back not finding google then you're not connecting to the webserver... need right dns numbers.
Mar 26, 2011 | Sylvania G-Netbook
When a number is entered, i.e., 2, six or seven times, vertical lines come up on screen. And, when "Y=" pressed, illegible letters come up. Please help?
try to clear the ram
2nd Alpha S enter enter
you should get a message when the ram is cleared
if you will not get the message then is a hardware failure
if you want to fix the unit let me know
ecrdn@yahoo.com
Jack
Oct 23, 2010 | Texas Instruments TI-83 Plus Calculator
I have tried to log in to messenger and windows live hotmail but they insist I am entering the wrong password. I know it is the right password
wait for sometime and restart ur pc and then do this Reregister SSL security libraries. To do this, click "Start," click "Run," and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command.
a. REGSVR32 softpub.dll b. REGSVR32 wintrust.dll now run reginout registry cleaner and then run msn messenger
Sep 26, 2010 | Microsoft Windows Live Messanger
Wii will not update, comes up with and error code message
Error Code: 32002 The Nintendo Wi-Fi Connection servers could be experiencing a high amount of traffic. Please try your connection again later.
If you have waited several hours and are still unable to connect, there could be an issue with your connection. Please review the folliwing information:
  • Ensure you have entered the correct DNS into the Wii console's manual settings (link). You can verify this by following these steps:
    1. Click the "Start" button in the lower left-hand corner of your computer.
    2. Click "Run."
    3. Type "cmd" into the box and press Enter.
    4. Type "IPCONFIG/ALL" and press Enter.
    5. The Subnet Mask, Default Gateway, Primary DNS (first listed), and Secondary DNS (second listed) information will be displayed. Ensure the information you have entered into the Wii console's Manual Settings appear exactly as displayed.
    6. If you have more than one DNS server listed, try switching the first and second in the Wii's primary and secondary DNS server slots.
  • Try temporarily disabling your router's firewall. *
  • If you are still receiving this error code, please click here for assistance.
    Nintendo Wi-Fi USB Connector
    Wii LAN Adapter
If you have tried the steps above but are still having issues connecting, it's possible that our servers may be temporarily down. Please try your connection again later.
*While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
Sep 25, 2009 | Nintendo Wii Console
I have sony VAIO VGN . I am not able to connect to wireless internet. Only local connection is established but does not connect to Internet. I have tried different locations and IPs.
It is because the DNS address may be set to static. make sure you insert the DNS ip address by right clicking on your network icon and then select status, then properties. select internet protocol then enter the static DNS address. you can obtain it from a machine connected to the network with internet access by typing ipconfig/all in a command prompt. hope this solve your problem.
to enter command prompt click on start then select run, and type cmd and press enter
Mar 14, 2009 | Computers & Internet
Microsoft Windows XP Home Edition Logo
47 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
