Question about Juki TL-98Q
I just got this machine new and feed dog
I just got this machine new and am setting it up. When I move the feed dog knob it wont make the feed dog go up or down.
    Problem Solver:
  • 15 Answers
It may just be stuck from being in storage and unused.
Try oiling the machine as per the manual, lowering the feed, and running the machine. The movement of the linkages may free things up. Another thing you can try is applying heat from the underside (open the bobbin access door and blow the heat in) as the heat will allow the oil to seep in better...then run the machine some more.
Posted on May 29, 2010
Cant get the feed teeth to come up and grab the cloth -- the cloth wont move --do I have it set on darn ?
it is possible that you have the feed in the neutral position ( halfway between forward and reverse ) from your problem discriotion
Apr 24, 2016 | Singer Sewing Machines
My sewing machine wont RUN. The needle goes up and down but the material wont move along.
under the foot around the needle, there should be two rows of what look like teeth, these pull the material through and there will be an adjustment mechanism on the machine. Try leaving the foot up while you run the machine, you should see the teeth going up and down; if they are it is most likely just a case of setting up the amount of pull. I think it is adjusted with the wheel that sets the length of stitch.
Apr 07, 2016 | Sewing Machines
Can't drop the feed dogs on my Bernina 1260
Could it be that the feed dog mechanism has not been oiled for a long time? I have a 930 and perform frequent all-over oiling including the feed dog mechanism (all-over refers to a couple drops of good quality sewing machine oil every place where metal rubs on metal). To get them working faster, try directing hot air from hairdryer into the internal mechanics to loosen things.
How can get the reverse lever to work Sewing Machines
It was working now it seems to be frozen the needle part wont move
Feb 08, 2016 | Sewing Machines
I have a Necchi 537FA and I want to know what the knob (on the right hand side) with the dot and knit symbol does. This knob is the last one on the right hand side. Thanks in advance for the help.
I suspect the knob on the lower right hand side is the feed dog knob. The "knit" symbol is for the feed dog. One setting drops the feed dogs so you can move the fabric yourself, ie free motion quilting. The other setting raises the feed dogs so the machine will feed the fabric for you.
to find a manual, Search the internet:
Brand + Model + the word "Manual"
Aug 19, 2015 | Necchi Sewing Machines
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
Thats because you have a part in their thats been moved or shifted dont try anything call your technician to help you remove the broken part or remove it!! Ok
Mar 25, 2010 | Juki TL-98Q
Singer stylist sewing machine 534 is not stitching
Its quite possible that the stitch length knob is set on 0 or that you have the feeddogs set on darning which drops them below the plate (if it has this feature). Otherwise the feedogs are gummed up and everything needs a good cleaning and oiling.
Hope this helps.
Rick
Feb 13, 2009 | Singer Sewing Machines
Machine works but doesnt move forward
Could be that the feed dog is in the down position. The feed dog consists of serrated sections which move together under the fabric and move it under the needle. Run the machine unthreaded and you should see the serrated sections lift above the needle plate, move forward and then drop again. If this doesn't happen the "drop feed dog" knob on the front of the machine could be pushed in. Look for a small knob about 1/2 inch across on the right front of the machine. Push on it and move it sideways at the same time. If it pops out this means that the feed dog is now up and you should be able to sew.
Aug 26, 2008 | Husqvarna Viking 1
Juki TL-98Q Logo
204 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
