Wharfedale recones??? Hi, I have a pair of Wharfedale EVP-x15 speakers that both threw the woofers at the same time. My bad... the specs say 600 watt program/1200 watt peak, in my world that means they should handle 1000 watts... they don't, lol Is it possible to find recone kits for the d-644 woofers or should I just replace them with a peavey driver? Please share any info... [email protected] Thanks, Rick
SOURCE:
SOURCE: Wharfedale Moviestar 60+...
witch company your sub woofer. aleredy company has given user manuval see connections in manuval okkk
Posted on Mar 15, 2008
SOURCE: reg: Cerwin-Vega! 250SE 125 watt
i had the same problem & got them fixed at a professional audio place in town & now my speakers are like new. They will last me another 10 years. I suggest you have them fixed by a professional.
Posted on Aug 25, 2008
  • 4234 Answers
SOURCE: Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Posted on Sep 24, 2008
  • 124 Answers
SOURCE: woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Posted on Jan 04, 2009
  • 119 Answers
SOURCE: speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Posted on Feb 25, 2009
Wharfedale Modus one six - one woofer cone is cracked. It still plays, but needs to be replaced. Where can I buy a replacement, or is it possible to repair the cone?
Yes, you can bring it to electronic repair shop to rewind the coil. or buy it in the electronic shop. if they don't have same brand you can replaced it with other brand same size and same watts of speakers. thanks
Apr 30, 2011 | Wharfedale Modus One-Six Speaker
Hello, I have a woofer from a set of diamond 8.3 Wharfedale speaker. The woofer sounds like the coild is rubbing and emits a scratching sound. Looking for possible repir solution and the model no. for the...
Hello
The voice coil of your speaker is scratching with its magenet body inside. It can't be repaired. Whatever we do will go in vein. there is no possibility other than replacing this speaker. Some people will recone it, but qulaity cannot be assured. it will sound; but with respect to the other speaker, it won't match. Coil position, resistance, number of turns per unit length ete are determining the magnetic strenth of the coil, and therby sound. Wharfedale eill have its secret, and they wont give it out, as they have gained it with tremndous reserch.
So in my opinion, it will be best for you to replace the damaged speaker with and other one of same type and number. All details will be printed on its body. Buy the original one. Do not compromise. Woofers are the heart of any sound system. Keep this in mind. OK.
Mar 31, 2011 | Wharfedale Diamond 8 Cinema System
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
I need user manual of Wharfedale topaz SW-12. Where I find it. thaks
WHARFEDALE Topaz SW-12 Subwoofe
connected to Sony STR-DE975 at the sub-
woofer out-put only hums, ??
thanks
Sep 06, 2010 | Wharfedale Topaz SW-12 Subwoofer
Speaker connection from Denon AVR 2105 to Wharfedale suround
Jan 27, 2009 | Denon AVR-2105 Receiver
Wharfedale 8.3
Is it old ? Is it making a rattling noise inside ? Completely lost its sound as in completely stopped sounding like a woofer and has higher frequencys coming out of it or as in no sound at all coming out of it ? I would say it's probably the crossover, perhaps a burnt resistor.
Aug 05, 2008 | Wharfedale Diamond 8.3 Main / Stereo...
Mar 12, 2008 | Wharfedale Moviestar 60+ System
446 people viewed this question
Ekse
 Grubhead
Grubhead
