Question about Sony Ericsson K610i Cellular Phone
Charging problems i got my phone wet. it worked for a while then the first time i ran the battery completely dead and tried to charge it again my phone siad use "genuine battery -power off-" and the same thing happens when i unplug it and trie to turn it on and then it turns off in ten seconds if it isnt plugged up.
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center and have them fully service the phone for you.
Posted on Oct 25, 2008
SOURCE:
Hello....my phone BLU Life play is completely dead now. The day before thanksgiving my phone was working perfectly find then of course. My battery. Was at 20% so I tried charging it and I notice that it...
Try using someone else's battery in your phone and/or your battery in their phone and try charging it and turning them on. If your phone turns on now, then its something wrong w/ the battery, if not... then its something wrong with your phone. Is there any possibility that it got wet? If so, take the battery out immediately (although its probably way too late after all the attempted charging), pour some rice into a small tupperware or other sealable container, snug your phone into the rice, then bury it completely in more rice and seal the container and LEAVE IT ALONE for at least a couple days. After u take it out and plug it in... go do something away from the phone for a bit... cuz it sometimes will take a while of looking like nothing is happening. I don't know what the notification light is like on that phone. But on mine, after probably 20 minutes of nothing while charging... the charging light started to flash (indicating that it is charging, but not yet ready to be turned on), once the light was solid on, turned the phone on no problem.
Nov 30, 2013 | Cell Phones
Won't work at all. The battery ran low, I plugged it into the charger as usual........it didn't vibrate or beep as normal............now I can switch it on.......but it never goes past the apple icon...
Either your battery is completely dead and needs to be replaced, or you just need to let it sit and charge for awhile. Mine did kinda the same thing and i let it charge for a few hours and started it up again and it was fine.
Mar 03, 2011 | Apple iPhone 3G
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
My phone is not holding a charge. It seems completely dead, and when I try and charge it it flashes sporodically and vibrates for a second or two before dying again
When your phone tries to come on and goes back off after vibrating for a second or two.
This is due to the fact that the battery is completely dead and is trying to pick up when you plugged it to the charger.
Try to charge the battery of your phone in another phone before fixing it back into your phone.
turn it on before trying to charge it again.
make sure the battery never runs out before you charge it back.
take care
Jun 12, 2010 | Sony Ericsson K850i Mobile Phone
My phone was working fine yesterday, It ran out of charge last night and when I put it on the charger thismorning it now just flashes white screen every 5 seconds or so ... is it dead ? cheers Wal
The phone should never be left to die out of charge anytime for good health of battery and phone.
So the problem is that the battery has completely died out so its not getting charged again, it bound to happen sometimes. So all you need to do is get it to a repair shop and just boost the battery initially so that it starts charging again.
Its similar to jump start in a car. So do not worry its a cheap fix only and never let it again to die out of charge.
Nov 21, 2009 | Sony Ericsson W850i Cellular Phone
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
Phone is completely dead- will not switch on - battery was not flat as recently charged. tried to charge it again but no response
may be there is some problem with battery try putting any of ur frnd s handset compatible battery in to it and just have cross check ...
may be the battery is dead due some indeed things like overcharging or bcoz of heating effect....
may be power on button inside is gone...
or the charging ic is gone....
if problem persists then contact the technician ...
this simple problem he will not charge more than 300 ..
Feb 07, 2008 | Sony Ericsson W200i Cellular Phone
Phone suddenly stopped working
The rechargeable battery may be failing to recharge.
Dec 17, 2017 | LG Radio Communications
Battery charge
Put 2 batteries in flashlight and ran completely dead. Charged them in 1hr. 50min. Pulled plug per directions for first time charge and plugged back in. Light went out in about 10 - 15 min. Plugged in third time with same results. Is this normal. Haven't tried them in camera yet.
Sep 13, 2005 | Epson PhotoPC 800 Digital Camera
Sony Ericsson K610i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
