Question about Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS
Had a power outage and the wh40 is not turning back on
  • 3,287 Answers
Check and adjust time of day. If the outage lasted long enough, the water may be heated when you go to bed and cool off by the time you need it. Don't attempt to move the pointer! Pull the timer dial away from the box, while holding the dial - twist it in either direction so that the pointer is on the current time of day. Release the dial to it's original (in) position.
You can get the manual here.
Please rate this reply - thanks!
Posted on Dec 17, 2010
Intermatic WH40 will not "turn on" trip switch but will do the turn off trip switch. Why?
Make sure there one silver and one black adjustable trip pins on the dial. One is for on abd one is for off.
Feb 20, 2015 | Intermatic Wh40 Water Heater Timer Switch
My WH40 makes a loud hum, but it works well. It is about 20 years old, and didn't make this noise until fairly recently. Could the motor be requiring replacing?
1) Yes, the noise is from clock motor turning the gears.
When timer is new, parts have a bit of white grease on them.
Turn off power and spray WD 40 or apply some white grease and see if that helps.
2) Yes
WG1573 240Volt clock motor is going bad.
Tip out mechanism using thumb spring located top inside box and check clock motor number.
Buy
WG1573 240Volt clock motor and extra trippers from Granger number 1PNK2
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
http://waterheatertimer.org/How-to-wire-WH40.html
Notice on image below, there is a bit of white grease on lever.
This photo is from new WH40.
Feb 22, 2011 | Intermatic WH40 - Water Heater Time Switch...
I have an intermatic WH40 timer that works great when it is "On". However, once the unit encounters the "Off tripper", it turns the hot water power off, but the timer dial no longer...
If this is new installation, you have Load wires and Breaker wires reversed.
http://waterheatertimer.org/images/WH40-water-heater-circuit-5.jpg
Hot wires from breaker connect to terminals 1 and 3 ... notice also there are small white wires connected to terminals 1 and 3.
Small white wires go to 240Volt clock motor located on back of mechanism, so these terminals have to be Hot all the time so clock motor is ON all the time >> thus hot wires from breaker connect to same terminals that have small white wires.
Load wires to water heater connect to terminals 2 and 4
Reverse your wires and things should work fine.
Dec 05, 2010 | Intermatic WH40 - Water Heater Time Switch...
Timer will not turn water heater ON at set time, has to be done manually. However, it will turn water heater OFF at set time.
If this is new installation, check wiring. Hot and Load wires might be reversed.
Check that ON OFF trippers are both attached to yellow dial.
If timer worked fine before, and started missing recently, then tripper pins probably worn out.
Trippers contact mechanical lever, and push lever on-and-off.
Trippers are softer metal and designed to wear out before lever.
If lever is worn out, timer needs to be replaced, but try new trippers first.
Buy trippers at Grainger
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
How WH40 timer works:
Clock motor rotates dial.
ON-OFF trippers on dial contact lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever other direction.
Lever moves electrical contacts together, or pulls contacts apart.
When lever moves on-and-off, manual override lever also snaps back and forth with audible clicking sound.
Using q-tip, add touch of white grease to lever where trippers contact.
Nov 25, 2010 | Intermatic WH40 - Water Heater Time Switch...
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
Oct 28, 2010 | Intermatic WH40 - Water Heater Time Switch...
How to set clock time for intermatic wh40 electric ?
DO NOT attempt to move the pointer!
With the power OFF, pull and hold the timer dial OUT. Twist the dial in either direction to align the current time with the pointer. Let the dial return to the original (in) position. You'll have to do this whenever DST changes and after power outages.
The manual for the WH40 can be downloaded for free, here.
Sep 03, 2010 | Intermatic WH40 - Water Heater Time Switch...
My experience with these is that there is no way to fix them. The power surge either took out the motor that runs the time clock or it took out the contacts that close to feed power to the water heater. In either case the best fix is to replace the timer. If you get a new one like what you have, it is very easy to pop the board out of the metal box and then all you have to do is rewire the new board exactly as the old one is.
heatman101
Mar 25, 2010 | Intermatic WH40 - Water Heater Time Switch...
New Intermatic WH40 electric water heater timer for solar
make sure your line wire is on the correct connection seems to be connected to the off going contact. then the clockmotor runs only if timer is switched on. to be sur there is a diagram on electricsuppliesonline.com, search/shop by brand, intermatic. good luck
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
The water heater turns off and does not come back on except if turned on manually.
If this water heater is a gas heater and you have to manually turn up the thermostat each time to get the burner to come back on it could be gas control thermostat.
Nov 04, 2009 | Intermatic WH40 - Water Heater Time Switch...
Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS Logo
80 people viewed this question
Top Intermatic Water Heaters Experts
Steve
Gary Nitowski
Gene Haynes
Are you an Intermatic Water Heater Expert? Answer questions, earn points and help others
